Hey guys, been a while since i've posted anything on this forum!!.
Anyhow, heres my story:
Started hearing a rapping noise and it sounded almost like the Rod bearings or Main bearings were going bad. So I decided to check the oil pressure at idle and warmed up to normal temp. I hooked into the oil pressure switch location and it was reading 0Psi. So I thought to myself, "Thats not good at all..." Anyways, I started tearing into it and found out that the noise I was hearing was coming from the waterpump, and I replaced it with a new one. While replacing that, I decided to change the oil pump and pickup as well since I wasnt getting good pressure ( I pulled the oil pump from a known good working motor i had sitting around ). Hoping for the best. Well when I had my oil pan off, I noticed I had a small amount of shavings in the bottom of the pan. Not good. I ended up replacing the rod bearings and main bearings while i had everything apart (without checking clearance between the bearings and crank with plastigauge). I noticed that the 3rd main bearing (wider one) was where all my shavings were coming from. Cleaned the crank up checked for scratches and everything looked good.
I put everything back together, pulled all the ignition cables out and cranked the motor over to circulate the oil a little bit. Started it up with everything hooked up as far as timing goes and it started up right away and seemed to run great. I was thinking, "Bonus.. it sounds good!". I thought, I might as well check the oil pressure now and checked it when the motor was still cold. Started up and was at 25Psi but once it started heating up it dropped to 0psi. Now I was getting a little aggravated, so I decided to change the oil filter Relief Valve with a known good valve too thinking that maybe the valve was screwing with the pressure somehow. No luck.
Do you guys have any ideas of what the problem could be ? Thanks in advance. Sorry for the long story but I figured it would be better if you knew the whole story of whats been done already.
Also, the car has 212,558 miles on the motor and it is a 5sfe out of a 1992 toyota camry LE.
Brandon
Also, Here is a few pictures I took:
In this picture you notice the shavings and then that stuff underneath it. It is actually JB-Weld and the previous owner "patched" the pan. Was replaced with a good oil pan.
