Originally Posted by Buurin
Just when I want to mention gen 4 dogbone swap.
Fill the bad mounts with polyurethane. I raised the same discussion over at the gen 8 corolla forum and someone put up a link to a honda forum (!) which leads to a DIY.
Polyurethane works, I've found the best way to fix a bad motor mount is just to go to the salvage yard (You Pull You Save is cheap) and just get one in good shape there. They are really simple to remove, All you need is either a motor picker or a floor jack / block of wood. Either lift up up from the top, or jack the motor off of the mount from below. The Polyurethane will work though just to let you know. I fixed a dogbone that way and it worked for a long time.. I ended up getting one from the salvage yard after it broke a second time but yeah thats my 2Cents
