1994 v6 camry starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2010, 12:49 PM   #1 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
recently, my 94 camry v6 has some starting issue, well, i am not sure if it is a problem, and didn't do that before.
when the car sit over night, or after work, i insert the key in ignition, wait a few seconds, then crank the car at once, nothing happen, not even clicking like machine gun, and the dash light are not dimming, it acts like starter relay was disabled. then i proceed to 2nd crank, and i hear the starter turns the engine, and the car starts, sometime need 3rd try, and it runs fines.
this morning, i also connected the jumper battery to the vehicle battery try to give the battery a boost, and 1st try, it cranks the engine 2 or 3 seonds, but not enough to start engine, so i proceed 2nd crank, and it started the car.
i am trying to figure out what cause this problem?
in my head,
battery weak?
starter relay going bad?
starter going bad?
throttle body need cleaning?
need new engine air filter?
any advice will be appreciated.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 10-06-2010, 12:54 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
bad connection at the battery posts i'd bet. and by bad i mean its loose.
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 10-06-2010, 01:10 PM   #3 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
Or your ignition switch is going bad.
LittleWhiteBubble is offline   Reply With Quote
Old 10-07-2010, 09:20 AM   #4 (permalink)
you are right
i inspected and tighten the negative post, and now start on 1st crank
thanks
Old 10-14-2010, 09:20 AM   #5 (permalink)
here is an update to my 94 camry v6 starting problem
it is not the battery, not the battery cable loose
like i explained earlier, sometime it starts right away, sometime it just click once
and i've done more testing, and found once i start the car and let it warm up, then shut off engine, try to restart, and i hear one click dash light not even dimming, but once the engine started, everything seems fine,
and the starting problem getting worst each day, and one time i got fed up and have to use the steering wheel club to tap the starter a few time to start the engine.
got a used, but tested working starter from junkyard
took an hour to replace, i under estimate the job, thought might only take 10 to 15 minutes, but need to remove battery, cruise control unit, air intake filter box.
and now seem it fixed the problem.
original starter having problem, only has 170k miles.
Old 10-14-2010, 10:40 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
you can re-build those starters too. $80.00 to have someone else do it, cheaper if you buy the parts and do it yourself.
Old 10-14-2010, 11:08 AM   #7 (permalink)
hmmm, my uncle work in junkyard, he gave me the starter for free.
but i will save the old one to see if all i need is just the copper contacts on the solenoid.
Old 10-14-2010, 02:51 PM   #8 (permalink)
View korrupt1's Photo Gallery
or as mentioned the ignition switch in the column is possibly going out...can MAYBE trying cleaning it out with some contact cleaner...keys, like money, can get incredibly dirty and grimy, that gets into the switch and can cause bad connections also....its only a possibilty, but never hurts to try.
I clean my keys regurarly(sp?) and I have never had a issue with bad contacts or connections....but I am also EXTREMELY anal about alot of things
korrupt1 is offline   Reply With Quote
Old 10-14-2010, 04:10 PM   #9 (permalink)
Gameroom cash: $303255
"sometime it just click once"
That's the classic sign of worn out starter solenoid contacts. Save that old starter. Do a search on this forum for "starter contacts" and read up on the problem and it's cure. It's been covered here numerous times. For a few dollars you can replace the starter solenoid contacts and have a spare starter.
Mike
Mike Gerber is online now   Reply With Quote
