95 camry black smoke and fuel consumption - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2010, 06:13 PM   #1 (permalink)
View cranksonsor's Photo Gallery
USA 95 camry black smoke and fuel consumption
Engine Performance problem
1995 Toyota Camry 4 cyl Two Wheel Drive Automatic 130000 miles
Hi! I have a 95 toyota camry and a guy put an used engine for me and Im sure he has some hoses backwords. One hose from the Map sensor is off and dont know where it should be and the car has a low idle . and if i puch the gas pedal heavy black smoke comes out of the tailepipe and i spent alot of money on fuel now and as you can see on the pictures, the hose that come from the Map sensor is off and i have no idea where it should go and also when i take that hose off in the pictuer number 3 the car idles normale and when i put it back the car seems like it wants to shut off. Do you think that could be the problem??? please help and if anybody can send me some pictures of where those hoses go I would really appreciat it.
Thanks
this hose from Map sonsor been disconnected for a month
When i take this hoes off he idle becomes normal and when i put it back it stalls and the other hoes is for the brake booster.
and i dont have any idea whats this for.
Please be free to ask any questions .
Thanks
cranksonsor is offline   Reply With Quote
Old 10-06-2010, 06:55 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
that last picture is a Vacuume Switching Valve for the EGR. I see on that last picture you have also plugged a vacuum line with a screw too. Doesnt your camry have a Vacuume routing diagram??
heres some pictures I took in the dark . lol sorry,
you definately have to move a couple of those lines. i will take better pictures when it is light outside, unless someone has better pictures already..
also, my vacuume lines are probably longer than most people's because I changed out bad vaccume lines with ones off of a spare motor and some ended up being longer
The Following User Says Thank You to Mister_Perkins For This Useful Post:
cranksonsor (10-06-2010)
Old 10-06-2010, 07:11 PM   #3 (permalink)
try switching those lines to what i have the arrows showing
Old 10-06-2010, 07:39 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
disconnected MAP will cause very low idle. get it connected as Mr Perkins suggests, he seems to have same engine as you (mine is gen4 5sfe, different hoses on the head).
you should get all hoses connected as vacuum routing diagram shows, otherwise expect strange things.
The Following User Says Thank You to fenixus For This Useful Post:
Old 10-06-2010, 07:52 PM   #5 (permalink)
lol . See on my camry when i put the motor in, I was really confused because it was doing the same exact thing... It ended up being broken wires to the mapsensor Took almost 2 days to figure that one out. So if your car gets connected up correctly and still runs really rough, make sure to check your wiring to your map sensor:
Old 10-06-2010, 08:06 PM   #6 (permalink)
Thanks so much for you effort guys i really appreciate it and Im sure the hoses are backwards on my intake manifold and I'll try to put them in the correct way and i'll let you know the result.
Thanks
Old 10-06-2010, 08:13 PM   #7 (permalink)
'' that last picture is a Vacuume Switching Valve for the EGR. I see on that last picture you have also plugged a vacuum line with a screw too. Doesnt your camry have a Vacuume routing diagram??"
I dont have no idea why that hoes is plugged Man Lol. and i think with some better pictures that would be so easy for me to figure it out .
Thanks again so much
Old 10-06-2010, 08:23 PM   #8 (permalink)
If you go by the picture that I drew the arrows on you should be fine
Old 10-06-2010, 08:42 PM   #9 (permalink)
I will do that.
Thank you
Old 10-09-2010, 06:04 PM   #10 (permalink)
Hi!
I tried to do the same thiong that you draw for me last time and i got confused and also the Vacuume diagram that you sent me is it for 95 camry ? I thik i have extra hoes or somthing but Anyhow i would really like if you could take a small video showing where those hoes goes Please. i would really appreciate that I f possible.
Thanks alot again
Old 10-09-2010, 06:10 PM   #11 (permalink)
Yeah I could do that. I actually have a motor that is taken apart right now, I will take some pictures to show you where things go since everything is apart. Maybe a video too to help you.. i will post tomorrow some time
cranksonsor (10-09-2010)
Old 10-09-2010, 06:17 PM   #12 (permalink)
the most pain in the butt vacuum line is the one that is on the under-side of the intake manifold. As you can see from the picture below. There is actually 2 vacuum lines on this switch. I can almost guarantee this is where your problem is at as far as vacuum routing goes. ( pic was borrowed from fenixus's F/S Thread )
Old 10-09-2010, 06:42 PM   #13 (permalink)
Thank you so much and Im sure that would be so helpful to me .
Thanks again
Old 10-09-2010, 07:02 PM   #14 (permalink)
I will be availabale tomorrow morning if you wanna post a video and pictuers and i will try to start trying again to make every works before i get crazy. lol
Thank you so much sir
Old 10-09-2010, 07:05 PM   #15 (permalink)
no problem, glad to help you out. I know the Vacuum routing can be really frustrating..
