Engine is out..what would you replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2010, 07:35 AM   #1 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
my moms car needed a new engine (tapping from cyl 1, 172k, believed to be main bearing).
Got an entire junked 99 camry with low miles - both engines are resting on the mounts, ready to come out.
I plan to replace the following while the engine is out
Timing Belt
Tensioner
water pump
mounts
Am I missing anything obvious that would be easy to do now, instead of later?
Thanks
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 10-09-2010, 07:51 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
You might as well replace as many seals as you can on the new engine.
You might wanna take a peak under the oil pan and valve cover to make sure your new engine isn't junk.
If cash is an issue I would leave the mounts from the low mile engine. They tend to last a while.
carsrus is offline   Reply With Quote
Old 10-09-2010, 08:04 AM   #3 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
oil pump seal, rear main seal, thermostat, spark plugs.
It probably doesn't need the rear main, but it really is a pita to do later.
The thermostat I recommend because they have a tenancy to not work so well after sitting not used for a long period of time with the rubber seal drying out.
SexieWASD is offline   Reply With Quote
Old 10-09-2010, 10:03 AM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I've made this mistake before. Just replace EVERY seal. It's a billion times easier now. Even the rear main. If you don't, luck will have it they start to leak after you put it back in.
I would also do all the gaskets. Again, it's a lot easier right now.
Chris Crash is offline   Reply With Quote
Old 10-09-2010, 10:13 AM   #5 (permalink)
I wrench, therefore I am!
Gameroom cash: $213700
View TedL's Photo Gallery
In addition to what's been said, if it's a 6, I'd do the valve cover gaskets. On a 4, I'd do it if any leaking shows. Access is easy later on.
On a 4, the VSV for EGR can be a pain to access. If it's on the new engine, test it--or go with your old, working one. Clean EGR and TB.
TedL is offline   Reply With Quote
Old 10-09-2010, 11:09 AM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Adding a few items and summarizing the excellent parts suggestions from fellow TN members:
(using rockauto.com, you can find online dealers too):
AISIN Part TKT002 (timing belt, 2 pulleys, and pump) $106.79
(or similar GATES TCKWP199 $73.79)
GATES Part # K030295 PS belt $4.93
GATES Part # K050435 Alt/AC $14.39
FEL-PRO TCS45641 Cam seal $3.71
FEL-PRO TCS45920 Crank seal $5.59
BCA Part # 221820 Oil pump seal $2.98
FEL-PRO VS50304R1 valve cover gasket set $19.44
FEL-PRO BS40427 Rear Main Seal set $10.41
FEL-PRO OS30468C Oil Pan Gasket $7.82
New tensioner pulley spring from the dealer (~$5).
FEL-PRO SS72810 Valve stem seal set $32.89
Thermostat and gasket (use OEM only)
Radiator hoses (both, but at least the upper)
PCV valve and grommet
Spark plugs (I prefer NGK Iridium-IX).
Spark plug wire set?
Clean EGR, EGR VSV, EGR pipe
Clean throttle body and IAC valve
Engine mounts (or no mounts)
(Is the new engine in good shape?)
The Following User Says Thank You to JohnGD For This Useful Post:
reluctantmechanic (10-09-2010)
Old 10-09-2010, 11:20 AM   #7 (permalink)
Thanks everyone, and esp JohnGD.
took a couple of pictures:
Overall, not too bad - had one seized exhaust bolt that I had to cut (in a tight spot) and one very fussy CV axles that didn't want to come out, other than that, it was smooth sailing.
Old 10-09-2010, 11:37 AM   #8 (permalink)
You're welcome!
Looks like the valve cover gasket is already leaking and sending some oil down the back of the engine (firewall side).
It may be a good time to replace the fuel filter (watch for seized lower flare nut that can twist the fuel pipe!).
And with the transmission out too maybe drop the pan and replace the strainer and wipe clean the pan/magnets.
Old 10-09-2010, 07:41 PM   #9 (permalink)
Originally Posted by JohnGD View Post
You're welcome!
ummm, in addition to the leaking cover, the majority of that is the inner pass side boot (split) and slinging grease every which way.
The new(er) engine is now out of the donor car - I start swapping pieces over tomorrow
Old 10-09-2010, 07:49 PM   #10 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
How many miles on the 99?
Zembonez is offline   Reply With Quote
Old 10-10-2010, 07:03 AM   #11 (permalink)
110,000k
