I have a 1998 Camry. After the flex pipe is replaced (i.e. cut it out and weld a new one in place), I hear the whisper sound when pushing the gas pad during the driving. When I go back to the shop, the guy says this part is new and it takes time to carbonize. He asks me to drive 100 ~ 200 miles and then go back if it still exists. Is this bullshit?
What I'm thinking is that some place is not well welded.
After driving a while, I still hear the whisper. Is there any way which I could use easily to locate the little hole(s)?
You'll have to do it cold but you could use a spray bottle filled with soap and water. Look quick before the exhaust comes to temp and evaporates it before you can see the bubbles...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
you could always push your hand over the exhaust where it exits the car and feel if it has pressure too. this will confirm an exhaust leak if there is one. If there is no leak then it should build up pressure and try to blow your hand off the exhaust. If there is a leak there will be very little pressure or none at all and you will hear the exhaust escaping wherever the exhaust leak is
Yes - he is full of shite - you don't want it to carbonize since it will only get worse and may be a little harder to weld when you get back to his shop. I had a full exhaust done earlier this year and after driving it a mile or so I pulled a Uey and headed straight back to the shop and they fixed it on the spot. I got under the car and placed my hands around all the welds looking for pinholes.
"Here's one...wait, here's another one..."
Get it fixed correctly now and avoid troubles later. Besides, you also run the risk of getting exhaust in your cabin (mine does from time to time now and it smells awful...) And I'm still not too happy with the workmanship, but hey, this is Tennessee - can't be too picky I guess
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
hehe should have drove up to Pennsylvania, i could have put a nice bead on that exhaust
example: 1997 Chevy Cavalier Aftermarket exhaust I welded for my buddy
Somebody knows how to lay down a bead that's for sure.
The place that told you to drive around is full of it. A good weld will never leak, period, case closed, drop dead. They are just trying to get rid of you.
If you charged it with a credit card, put the charge in dispute. Tell them to fix it or you are going to withhold payment. Tell them if they don't fix it right, you will take it to another shop (hey Perkins you available?) and have it fixed right, and then you will take them to small claims court to get a judgment for what it took to make it right.
Print out a color copy of the weld that Mister_Perkins posted. And go back to the shop and wave the picture around, and tell them that you want the welds to look like this, or your are going to take it to somebody that knows how to weld.
Here is the follow-up. The guy who said "taking time to carbonize" tries to persuade me to replace more part of the exhausted pipe (of course, charge more). I said no. Then he used some glue (I don't what it's) on the welded part. The whisper was still there. So, I suspected that the part which was welded in had the problem. Finally, he agreed to replace the flex pipe with another one. After this is done this morning, the whisper is gone.
BTW, I saw he took a flex pipe from a big box which had more 7~8 flex pipes. I thought the shop used the poor quality part.
It sounds like this shop definitely does some shotty work.
That glue he put on there was either JB weld or Exhaust Compound (Black Goo).
Well at least you got it fixed.. I wouldn't recommend that shop to anyone though.
