Tie Rod removal. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2010, 03:48 PM   #1 (permalink)
Gameroom cash: $155150
View wilsonman02's Photo Gallery
Tie Rod removal.
I am working on my 2000 CE. I'm replacing the tie rod ends, i got the passenger side off and replaced already, but on the driver side tie rod, i cant get it off. Any tips or suggestions? Would taking a torch to it help? Any help would be great.
wilsonman02 is offline   Reply With Quote
Old 10-09-2010, 03:56 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Is the crown nut spinning along with the stud? If so you needa pry up on the joint to help it spin out.
The torch can never hurt taking old parts out if your careful.
carsrus is offline   Reply With Quote
Old 10-09-2010, 04:23 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yeah a torch would get it off of there. really isnt much else you can do with stubborn stuff like that. Just remember when you heat it up to let it cool down before you try to spin it off. You can risk breaking the soft metal when its heated. Also, I am not sure what torch you are talking about, but hopefully your talking about an o2/Acetylene torch. Propane torch will not work. Also helps once you get it to budge a little bit to spray some wd-40 or some kind of lubricant in there, tighten it, loosen it. Repeat the step until removed. Make sure to put some anti-seize on the threads when you re-install your new tie-rod end too. Good Luck!
Old 10-10-2010, 09:36 AM   #4 (permalink)
Thanks for the help guys. Its actually not the crown nut, its the jam nut on the other side of the tie rod, i cant get it to break free.
