This is for 1996 Camry LE V6...I believe this is my first post...don't recall honestly anyways I have the dreaded
P0401 code...work already done is"
1. Replaced and tested EGR and it's hoses
2. Replaced and tested EGR
VSV and it's hoses
To test that replaced EGR system to check it was working correctly I followed the suggestion of the Camry forum to apply vacuum to EGR....which if OK or clear it would run rough or act as though it was gonna die. Which it did.
As per the EGR
VSV while UN-powered using attached hoses to the two used ports not the round filter port..I blew air which was felt either port so it was free flow in either direction. I applied power and the EGR VSV had no air flow from either side thru used ports. OK now my issue is I after replacing original VSV to current one I reset the code and like after well driven next morning shortly after turning car on as I was driving the engine warning light came on it is the P0141 again.
I did clean both the EGR and VSV. I am lost now and can't figure out what may be the problem and now I'm on my last month to pass emissions in order to by plate sticker.
Now a little history of purchase and work done...
I bought car from Sister and it had the P0141 code. I was told by seller that engine was replaced with Japanese engine which had 60+k miles on it the body/trans has currently 230k...about 12 months after replacing engine is when the code showed up. I bought Camry LE V6 and after research applied tests and replacement of parts mentioned above...I heard from a friend like a month ago that he had a friend experience the same or similar issue after replacing engine with Japanese engine and after plenty of time and money spent it was found out one of his sensors were faulty..I since tried to communicate with him with no luck. Any suggestions welcomed...TIA!!
