Manual Tranny INFO S51/S52/S53/E153 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2010, 01:27 AM   #1 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
EDIT: THIS INFO IS WRONG.
(S51 5spd, FWD)
-CAMRY & SOLARA 4 cyl 2.0L 1983-84
-COROLLA 4cyl 1.8L 1983-84
(S52 5spd, FWD)
-CAMRY & SOLARA 4 cyl 2.0L 1991
-CAMRY & SOLARA 4 cyl 2.2L 1992
-CAMRY & SOLARA 6 cyl 3.0L 1992-93
-CAMRY & SOLARA 4 cyl 2.0L 1984-91
-CAMRY & SOLARA 6 cyl 2.5L 1988-91
-CAMRY & SOLARA 4 cyl 2.2L 1992-01
-CAMRY & SOLARA 6 cyl 3.0L 1993-99
-CAMRY & SOLARA 6 cyl 3.0L 2000-01
-COROLLA 4cyl 1.8L 1984-85
(S53 5spd, FWD)
-CELICA 4 cyl 2.0L 1985-89
-CELICA 4 cyl 2.2L 1990-93
-CELICA 4 cyl 2.2L 1994-99
-MR2 & MR2 SPIDER 4 cyl 2.2L 1991-93
-MR2 & MR2 SPIDER 4 cyl 2.2L 1993-95
(E153 5spd, FWD)
-MR2 & MR2 SPIDER 4 cyl 2.0L 1992-93
-MR2 & MR2 SPIDER 4 cyl 2.0L 1990-92
-MR2 & MR2 SPIDER 4 cyl 2.0L 1993-95
source site
http://www.drivetrain.com/parts_cata...rhaul_kit.html
Last edited by LynchburgCSI; 10-13-2010 at 05:59 PM. Reason: Incorrect info warning.
project92camry is offline   Reply With Quote
Old 10-13-2010, 01:38 AM   #2 (permalink)
Pabloso
hmm i kno i copied this from the site correctly but i dont think the mr2 is fwd ?
Old 10-13-2010, 04:07 AM   #3 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
It's not, but it uses a transverse powertrain layout which is the same as a typical FWD layout. Since it's mid-mounted, it drives the rear wheels.
Also, the S53 isn't used on the MR2, the S54 is. The S53 was used on the 1990-1993 Celica and prior. For 1994-1999, the Celica also used the S54.
The S51 was used on the 3SFE/5SFE Camry up until 2001, not the S52. Toyota only changes the end number if a change in actual gear ratios takes place - the final drive doesn't count. For example, the S51 and S54 have completely different gearsets. Another example is the E350 from the tC and the E351 in the Camry; the E350 uses a 0.775 5th while the E351 uses a 0.731 5th.
(S52 5spd, FWD)
These are COMPLETELY inaccurate.
First off, the 2VZ was mated to the E52 or E56F2/E56F5 (AWD), then the 3VZ moved to the E53 (updated synchros and ratios). The 1MZ received the 1995 MR2's E153 with a longer final drive ratio for 1997-2001.
Typically, V6s have always used the E series transaxles, which are designed to take the extra torque. The same is true for supercharged or turbocharged 4 cylinders and AWD/4WD vehicles.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 10-13-2010, 01:19 PM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
My 97 2.2L has the S51...
Chris Crash is offline   Reply With Quote
Old 10-13-2010, 03:37 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I glanced at this rather quickly, and went... "well, this isn't right".
'07 Honda Ruckus Big Bore
Old 10-13-2010, 04:00 PM   #6 (permalink)
I also know for a fact that Celica's use the S51 trans because I got an overhaul kit for mine and when I had to find it, I had to search and pretend my car was a Celica.
Old 10-13-2010, 05:41 PM   #7 (permalink)
Pabloso
lol o well i tried.. maybe we should delete this i dont want to confuse anyone
Old 10-13-2010, 05:43 PM   #8 (permalink)
Pabloso
does anyone kno where i can find a website that shows info like this? like a list of all the trannys , make , model , yr
Old 10-13-2010, 05:58 PM   #9 (permalink)
Freakin Scooters
I don't want to lock or delete this thread... I'll just add a disclaimer. Just take a look at the wikipedia pages for each car. They're usually right. And you can always ask for specific info here!
Old 10-14-2010, 05:36 AM   #10 (permalink)
1MZ powered MR2
Celica's use the S53 up to 1993. That is, it uses the S51's output shaft and pinion gear for a 3.944 differential ratio. The gear ratios are completely different though, but they're pretty close to the S54. All S series transmissions of similar years have the same internals - just different gears/ratios.
1991 Toyota MR2 V6
Old 10-14-2010, 10:12 AM   #11 (permalink)
Ah. Well I used the internals that as you said were the same. But it definitely said S51 Celica on the box...
Old 10-14-2010, 06:21 PM   #12 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
im still amazed there's this much discrepency (sp) in stuff thats 15-20 years old... the way i see it
S51=Camry (long ratio box no questions asked)
S53=Celica
S54= MR2/Celica (different second gear ratio compared to S53 and The FD changes for the MR2 dont quote me i have to look it up)
E52=2VZ (Camry ES250)
E53=3VZ (Camry Es300)
E153 1MZ/3sgte (MR2, Camry FD's are different.)
i wanna go so far as to say no S52 exists. sorry for the redundancy...
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
