Transmission suddenly broke??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2010, 07:07 PM   #1 (permalink)
View echo987's Photo Gallery
USA Transmission suddenly broke???
I need some help figuring this one out. My wife took the car out. was about to get on the Freeway and the tranny suddenly stopped working. She said she was sitting at the light. went forward and suddenly lost power. transmission smelled a little hot but not too bad.
with the car running I checked each gear and nothing. When it is in gear the speedometer registers speed but the car doesn't move. When in park the car rolls as if in neutral.
The car is an 1996 Camry 4cyl with 168K. Automatic. Just had the tranny flushed a few months ago.
Fluid level is fine, no leaks. No diagnostic trouble codes.
Do you guys have any ideas? Could it be a busted CV axel?
The car used to feel like park would barley hold car from rolling, now it rolls in park and won't drive.
Thanks Guys.
echo987 is offline   Reply With Quote
Old 10-14-2010, 07:20 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
It could be an axle. These camrys need both axles to be hooked up for the car to move at all. Having an axle broke you would think that the Parking Pawl would still engage.
Firstly, Check your fluid. See if theres any fluid on the dipstick
After you check that, look around the transmission for Automatic Transmission fluid. If you see a lot of parts near the transmission "wet" looking or red underneath the car, you are in some trouble.
It sounds like its internal transmission problem, but its hard to say without knowing the above two statements..
If an axle broke, you probably would have heard CLUNK CLUNK CLUNK CLUNK sound as the axle would be spinning quickly hitting against the engine / subframe.
Go check those things though and let us know
Old 10-14-2010, 07:24 PM   #3 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
agree, but the odometer has me puzzled....I wonder if it's possible to have the lower ball joint fail enough to allow the entire axle to slip out? If so, it would have to the drivers side - the passengers side is held in by a bolt (wait, that might just be gen4)
Please do let us know.
OT
Will a gen3 4cyle trans fit a gen4 4cyle trans? Thanks
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 10-14-2010, 07:26 PM   #4 (permalink)
I am not sure, I know the Gen 3 has two different Transmission designs. I would suspect a transmission from a newer generation Gen 3 such as 95 or 96 MIGHT work
Another Question:
When the speedometer is moving as normal, did you hear or feel any vibration or clunking ? This would be a dead indication of a broken axle
If a lower ball joint failed, she probably would have wrecked.
I know that the Gen 3 Lower ball joints are held in by 3 bolts on the control arm and 1 bolt on the spindle assembly
She would have probably noticed the vehicle start pulling to one side very quickly as well if the ball joint partially pulled out.
The best thing you could do is get under the car, pull the transmission pan and check the pan for metal particles. This will confirm you have internal transmission damage.
If your car axles are good, These are the things that COULD be wrong with your transmission using the Symptoms Chart:
Park Locking Pawl
C/o OD Direct Clutch
Bo OD Clutch
Just keep this in mind. If a shift solenoid was faulty, you would probably be throwing a code. Your Parking Pawl isnt engaging, so that tells me its either axles or internal problem.
Old 10-14-2010, 07:44 PM   #5 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
Pretty sure a Gen4 auto tranny will bolt up to a Gen3 car and vice versa. Small possibility of the axles not being the same, however, but I think the whole drivetrain is interchangeable between both Gen3 and 4 vehicles...
Anyone confirm/debunk this?
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 10-14-2010, 07:47 PM   #6 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
sounds like the axle came apart at the transmission side so its just spinning freely. That would also explain why it wouldnt hold park. Or your differential somehow destroyed itself.
rusty9 is offline   Reply With Quote
Old 10-14-2010, 07:51 PM   #7 (permalink)
I think if he gets a 95 or 96 transmission it might work.
Old 10-14-2010, 07:56 PM   #8 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
So you're telling him in no uncertain terms, time for a new(er) car?
zythr is online now   Reply With Quote
Old 10-14-2010, 07:57 PM   #9 (permalink)
no not at all
its a fixable problem
The Following User Says Thank You to Mister_Perkins For This Useful Post:
reluctantmechanic (10-14-2010)
Old 10-14-2010, 08:09 PM   #10 (permalink)
No leaks, I even added a qt to see if that was the prob. put car in gear and speedo registers 10mph neither axel moving. Is the differential seperate from the trans? could it be a bad diff?
Old 10-14-2010, 08:35 PM   #11 (permalink)
Yeah that could be a possibility.
I would inspect the transmission pan
Old 10-14-2010, 08:42 PM   #12 (permalink)
could be...but ever time I've seen a diff fail in a fwd car (toyota, honda) the diff doesn't just go, the gears teeth will clatter, very loudly.
My mothers Camry did this a few years ago, when she would rev the engine, the diff gears would go "Bang, clack, clack....CLACK BANG" you could hear it for blocks away.
Old 10-14-2010, 08:45 PM   #13 (permalink)
I've also seen this happen on many vehicles. Most recently I saw it on a 4wd Jeep Cherokee. The differential was so broken that it actually was making the whole vehicle hop every time that the broken teeth got caught on what was left of the differential.
Old 10-14-2010, 09:09 PM   #14 (permalink)
I was just thinking of something. You may want to check your Torque Converter.
What MAY have happened is your torque converter failed (Thats why you got the smell).
While this happened. It seems the parking issue has been there for a while. It could be that the parking pawl spring just took the final step and completely broke leaving no tension on your parking pawl.
Just an idea
what a broken differential does ( pictures borrowed from mk2-1jz ) --- Transmission problem? Help!
echo987 (10-14-2010)
Old 10-14-2010, 09:13 PM   #15 (permalink)
I
OUCH! Thanks for sharing that...nice pics
The Following User Says Thank You to reluctantmechanic For This Useful Post:
