Gen3 4cyl Normal Idle Speed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2004, 06:34 PM   #1 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
Question Gen3 4cyl Normal Idle Speed?
Hi,
I was just wondering with a Camry Gen3 (5S-FE Engine) what is the normal idle speed when in 'D' and stopped?
my one is at 790-800rpm.....i dont know if this is normal , since it is shaking at this speed, but if i give it a little gas to lets say 900-1000rpm, the shaking reduces dramatically, and the car feels normal.
~ Terry
terrynham is offline   Reply With Quote
Old 04-14-2004, 09:07 PM   #2 (permalink)
Zzzz...Caught ya Sleepin'
View TRDCAMRY's Photo Gallery
I get 750-900 without any shaking. Sounds about right. Plus Under the hood it says idle speed should be 750rpm.
TOYOTAS RULE!!!!!!!!!!!
1995 Toyota Camry TRD
http://www.cardomain.com/id/kaystrd
TRDCAMRY is offline   Reply With Quote
Old 04-14-2004, 11:37 PM   #3 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
really? where under the hood does it say what the idle speed should be?
~ Terry
Old 04-15-2004, 01:01 AM   #4 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I idle a bit below 1k, probably like 800rpm.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 04-15-2004, 01:36 AM   #5 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
yeah 800ish shakes a little (like very little, barely noticable), shakes go away if i rev higher
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 04-15-2004, 01:48 AM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $110650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
~900rpm ...I had to reset my tach.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 04-15-2004, 02:48 AM   #7 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
ok, i misread my tacho (above) it idles at 730-780rpm and shakes a fair bit.....but if i rev it to about 900rpm the shaking is still noticable but is calm enough to bare.
so is there anyway to change the idle speed myself? or do you suggest i try looking at what else could be causing the problem before that?
~ Terry
Old 04-15-2004, 03:30 AM   #8 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
750 is what it should be, your engine mounts are probably worn
-Nick
Nick is offline   Reply With Quote
Old 04-15-2004, 06:21 AM   #9 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
possibly.....but how can you tell if they are worn? im sure they are not broken though
also i have heard alot of stuff here on TN that the Gen3 4cyl Camry has this problem as some sort of design fault.....is this true?
~ Terry
Old 04-15-2004, 07:27 AM   #10 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
It kind of is a design fault, and we gen2 people have the same issue
My idle floats b/w 500 and 700 rpm (which is admittedly low) and I get the same Bohemian Death Rattle you do. It's really not anything to worry about.
Steve
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 04-15-2004, 10:48 AM   #11 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
i stay round 1000
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 04-15-2004, 12:59 PM   #12 (permalink)
Zzzz
Originally posted by big_p31
i stay round 1000
I used to too, but after I put some injector cleaner in the tank, I started idling a bit lower than 1k rpm.
-mark
Old 04-15-2004, 05:59 PM   #13 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
750 rpm is the norm. If the car shakes real bad, you have bad mounts. The only way to adjust the idle is to tighten up the throttle cable. There is no idle adjustment.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 04-16-2004, 04:02 AM   #14 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
increasing the idle speed would obviously be my last resort
how would you know if the engine mounts are bad? other than the fact that the car is shaking .
also, i dont know if this related or not, but when I feel the car shaking, and I turn on the foglights, headlights, anything electrical, the shaking seems to be a bit stronger with every additional thing i turn on....... I dont think this is the problem, but might somewhat be a small contributing factor.
I had the alternator replaced a year ago, but I can't remember if the car shoke before the replacement since I just bought the car at that time
~ Terry
Old 04-16-2004, 07:02 AM   #15 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
Mine revs in the 800 range and also rattles when stopped and goes away with pressure from the gas. I was told that rack and pinion needed to be adjusted but im not to sure about that. I really dont think that turning on other electrical things would cause it though although...sometimes in my dads OLD toyota (79Supra) that does happen.
Admiral is offline   Reply With Quote
