I own a 1993 Camry V6 XLE andafter idrive it for any length of time i can smell a strong gasoline odor , any ideas on where or what mightbe causing this? my best guessis the strongest location is under the hood somewhere, but theres no visable leaks any where that i can see.
First thing to check is gas cap. Open your fuel door sniff around. If you get a strong odor and the cap is tight, check the o-ring seal on the cap. It may be dry rotted and in need of replacement. You smell gas while driving, I presume? How many miles on it?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
Since you are in the Chicago "rust belt area" and given the age of the car, I would also check the fuel filler neck itself for signs of rust and leaks.
^ crawl under the car and physically check the filler neck. also inspect it after filling the tank to see if there are any 'wet' spots. also after the car has been running for a bit, look under the car for 'wet' areas along the fuel lines and/or dripping on the ground.
