P0446 because of loose hose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2010, 09:01 AM   #1 (permalink)
View ras2000's Photo Gallery
I have a 2000 toyota camry .Had got P0446 OBD code few months back.Did some research and hubby decided to give it a shot by replacing VSV.Yesterday when he crawled down the car to replace VSV,he found a loose hose.After tightening it ,he checked after running 3 miles whether pressure is creating in fuel tank,but it didn't . So is the problem fixed for P0446.How long does it take for pressure to build up in fuel tank ??
ras2000 is offline   Reply With Quote
Old 10-18-2010, 09:49 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
to TN! Well, you need to reset the check engine light. Remove the negative cable on the battery for a few minutes... then reconnect it. Take the car for a drive. If the light comes back on, you still have an issue!
'07 Honda Ruckus Big Bore
Old 10-18-2010, 10:16 AM   #3 (permalink)
Thanks for the reply!! Yeah he did reset the codes.Will drive for few days and check if it got fixed.But could you please tell how long does it take to build up pressure in gas tank ??Earlier there was no pressure and now if again it starts to create pressure than sure might be the problem got fixed.
Old 10-18-2010, 10:20 AM   #4 (permalink)
Freakin Scooters
Great! I wouldn't worry about it unless the check engine light comes back on again. Anyways, i'm not entirely sure how long it takes. I did do some quick reading on how the system works. To my understanding from what I read the system checks for pressure every time you start the car and it only takes a few seconds. Maybe someone else can chime in and confirm.
The Following 2 Users Say Thank You to LynchburgCSI For This Useful Post:
GOOD (10-28-2010), ras2000 (10-18-2010)
Old 10-27-2010, 09:33 PM   #5 (permalink)
View alist's Photo Gallery
hello i have a 4th gen 2000 camry v6 and i just got a check engine light and the code is p0446 i checked the fourms and they are saying the vsv. is there any diy threads or pics avail for ref. any help will be needed..and also my trac off light is on as well is that normal.
alist is offline   Reply With Quote
Old 10-27-2010, 09:43 PM   #6 (permalink)
Freakin Scooters
The TRAC OFF light shouldn't be illuminated unless you press the trac off button. I'm not sure what can cause that issue though.
Check the DIY sticky on the main page for threads related to the P0446. Also search "P0446" and see what others have done to remedy the problem.
Tags
loose hose, no pressure in fuel tank, p0446
