Need help: Coolant + Suspension + Power Steering leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2010, 11:10 AM   #1 (permalink)
Gameroom cash: $325545
View adalex's Photo Gallery
4th Generation Need help: Coolant + Suspension + Power Steering leak?
Ok so a few weeks ago with 2wickedtoyz help I put tockico blue struts and H&r strut mounts on. I had it aligned and firestone said that the front left camber is -1.7 degrees and that I need
INSPECTION SERVICES
7003186 REMOVEAND REPLACE ECCENTRIC
BOLTS
7003189 ECCENTRIC ALIGNMENT BOLTS
at around 55mph+ driving straight my steering wheel shakes? from side to side, similiar to if u drive on the wake up strips on the side of the highway. also the other day when i was doing an errand for work i had my driver side window down and just idleing moving ie no gas and just creeping along I could here a tick tick noise coming from the left side of the car, currently I have the driver side front off the ground and theres no nail. so I have no clue what it could be, also a few days before the tick idling at a red light I could hear a sligh rattling from the front left corner into the cabin idk if its the bolts that the air box sits in rattling around. and ontop of all this when i accelerate hard I can hear a hi pitched rattling noise like a few scews in a glass jar jingling around. any help would be much appreciated. oh and i took a few pics of some wet spots idk if it will help. also i have a torn endlink, ill upload a pic of that in a minute
*********UPDATE 3********
I went to harbor freight today and got jackstands, took off the driver side wheel to check the rotors and to try and get a good look at the tear in the boot, got some pretty good pics.
****** UPDATE 2*******
On the advice of a few people I took a look at the passenger side and the axle seems fine but theres some weird oil paths
****UPDATE***
well i think i fixed the rattling the 3 bolts with the metal washers on them that bolt the bottom of the air box down don't rattle anymore i undid them all and retightened them. however i started unbolting the iac and remembered the guy that did the iac diy said he undid the radiator cap to realive pressure i did that and coolant oozed out of the top i looked at the resivour and its low, since i filled it up and i know its supposed to be halfway when the engine is warm and full when its cold. this is what the tank looks like now, (cold)
pic of torn endlink idk if it needs to be replaced, when i brought the car in a month ago and i mentioned it i asked about it later and the service manager is like its fine who said it was bad? and i told him i did
adalex is online now   Reply With Quote
Old 10-18-2010, 11:58 AM   #2 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
this could have ended very badly - you must be living right...
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 10-18-2010, 12:08 PM   #3 (permalink)
yea why? car is fine any idea? im stuck >.<
Old 10-18-2010, 12:25 PM   #4 (permalink)
I thought it looked like a broken CV axle (maybe)....the ticking sound is something I hear alot when an axle is bad - the grease looks like it could be from your axle - check your boots on the left side.
From the pictures, your inner boot is torn, and slinging grease...
The Following User Says Thank You to reluctantmechanic For This Useful Post:
adalex (10-19-2010)
Old 10-18-2010, 12:50 PM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
ticking sound could also be from a bent dust shield touching your rotor or drum too. Rust deposits build up on the top of the rotor or drum and when it spins around you hear a ticking sound everything the built up rust touches the shield. Probably not you problem, but i've seen it happen before
Old 10-18-2010, 04:38 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
hmm...that looks a little liek it is leaking out of your steering rack.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-18-2010, 04:47 PM   #7 (permalink)
well i washed off the fluid, if it is the steering rack hypothetically, how would i make it spray like that again? just drive it for a few miles?
Old 10-18-2010, 04:50 PM   #8 (permalink)
No dont drive it. Start it, leaving it in park and turn the wheel all the way to the left and then back to the right. Keep doing this. This will confirm a PS System leak
You could put a piece of dry cardboard or Paper towels under there to so if it drips you will see it easier
Power Steering Systems on the toyotas commonly leak here on these connections. They are setup like the rubber lines to brake calipers. They have a Little O-Ring that sometimes goes bad. My 95 camry and 93 camry both had this problem.. I drained the PS System, changed the O-Rings and problem solved
The Following User Says Thank You to Mister_Perkins For This Useful Post:
adalex (10-19-2010)
Old 10-19-2010, 09:25 AM   #9 (permalink)
ill check that in a few minutes just as a note, yesterday i hosed up the sub frame underneath thats right about the transmission pan and got all the fluid off, i felt underneath the boot that is right next to that and it was really oily so idk if that has anything to do with it. side note, how exactly do u drain the powersteering fluid?
Old 10-19-2010, 09:28 AM   #10 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Never seen racks leaking from the connections Mr Perkins mentioned. It much more likely is leaking from the boot and your photo shows it (wet boot and dry connections). Check the FAQ section for rack & pinion replacement tutorial.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 10-19-2010, 09:30 AM   #11 (permalink)
nvm saw the powersteering fluid diy, i assume power steering fluid is supposed to be red? :P mines black as hell lol
found it its not the power steering in the video in the middle of heavily oiled spot in the very most inner slit with my finger i could feel a hole
http://s72.photobucket.com/albums/i1...t=MOV00629.mp4
Old 10-19-2010, 12:08 PM   #12 (permalink)
the only time I see things leaking up is when a boot is ripped
Old 10-21-2010, 08:32 AM   #13 (permalink)
ok about 3 people suggested instead of going oem to get a axle from napa, can anybody tell me which one I need? I don't know if they are called axles or driveshaft. from the napa website. I have a 99 camry I4 without abs. on napa's website their listed as cv driveshaft. I need a new driverside without abs. thanks
http://www.napaonline.com/Search/Res...02&Ntk=Keyword
Old 10-21-2010, 09:00 AM   #14 (permalink)
I would call it an axle - when I think drive shaft, I think of a long shaft that goes from a transmission, to the rear wheels of the car (like most american/euro cars).
give me a minute, and I can take a picture of what it should look like...
Old 10-21-2010, 09:55 AM   #15 (permalink)
this is your drivers side - it's about 2 foot long - they might call it an "axle assembly" not sure, but this is what it looks like.
hope that helps
