Originally Posted by doozergreengrass
Radiator switch? (bottom of radiator). Follow the extension lead from it to where it is plugged in at top of radiator, when engine is running pull that plug at the top of the radiator and the fans should switch on.
I just found that from the repair manual. Thanks for your information. I guess you mentioned the ECT switch. The fans should switch on if I unplug that switch. From the manual, if not, I should check the "fan main relay". "cooling fan relay", "cooling fan", fuses and the short circuit between the cooling fan relay and ECT switch.
Since the fans is OK when AC is on. I think the fan main relay and the cooling fan should be OK. Right? Should I check any fuses? Thanks!
Originally Posted by Zembonez
Sounds like a coolant temp circuit is malfunctioning. Most likely the coolant temp sensor as mentioned above. Driving in 2nd really should not have anything to do with it.
The temp is high (in the red zone) when I drove.
