Originally Posted by ty**20
Hey folks, does the 1MZFE engine have a coolant bleeding value anywhere on the engine? My hanes manual mention about this, but it never tell where is located. Anybody know where it is? Pics. will be awesome.
Also when I drain the coolant from the block. If I pour coolant into the cap at the upper hose is, will the coolant go straight to the block (when car is jacked at front). Or do coolant needs to go through the thermostat (in the lower hose) and into the block? Thanks,
This is the procedure from my Haynes manual (for a refill after a drain):
1. Close and tighten the radiator drain. Install and tighten the block drain plug.
2. Place the heater temperature control in the maximum heat position.
3. Slowly add new coolant (a 50/50 mixture of water and antifreeze) to the
radiator until it's full. Add coolant to the reservoir up to the lower mark.
4. Leave the radiator cap off and run the engine in a well-ventilated area until
the thermostat opens (coolant will begin flowing through the radiator and
the upper radiator hose will become hot.)
5. Turn the engine off and let it cool. Add more coolant mixture to bring the level
back up to the lip on the radiator filler neck.
6. Squeeze the upper radiator hose to expel air, then add more coolant mixture
if necessary. Replace the radiator cap.
7. Start the engine, allow it to reach normal operating temperature and check for
leaks.
There is no bleeder valve
