Question for 3VZ-FE: O2 Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2010, 06:09 PM   #1 (permalink)
93 Camry XLE
jets1934's Avatar
View jets1934's Photo Gallery
I have a 1993 camry xle V6. where the hell is the second O2 sensor. Checked haynes and toyota manual still cant find the second. I found the obvious one behind the radiator next to the exhaust manifold
jets1934 is offline   Reply With Quote
Old 10-24-2010, 06:45 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
on the rear bank down pipe. just infront of the firewall. its very hard to get to or see from up top because of the tilt of the engine.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-24-2010, 08:30 PM   #3 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
I bet it at the same location where it is in 1mz
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 10-24-2010, 08:47 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
It pretty much is. HARD to get to.... I hate replacing that O2 sensor.
'07 Honda Ruckus Big Bore
Old 10-24-2010, 09:07 PM   #5 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
DINGDINGDING!
you got it!
and yeah, it's impossible to reach from above because of the engine's tilt, you'll have to go from underneath. GL!
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 10-24-2010, 09:12 PM   #6 (permalink)
Nervous's Avatar
After replacing whole rear exhaust manifold replacing the rear O2 sensor is a piece of cake for me
Old 10-24-2010, 09:15 PM   #7 (permalink)
Nervous's Avatar
The rear O2 sensor is in this exhaust manifold (it is a pic of rear side of engine (that is closer to firewall).
Old 11-02-2010, 11:25 AM   #8 (permalink)
93 Camry XLE
jets1934's Avatar
instruction on 3mvze V6 O2 sensor needed
I am trying to remove the 2nd o2 sensor on my 1993 camry V6 3vze engine. I need instructions on how to get to it. It is located on the rear of the engine almost against the fire wall . I cannot get to it from above or below. Has anyone replace it yet,..if so how did you do it..some instructions would be nice..thanks
Old 11-02-2010, 02:44 PM   #9 (permalink)
Freakin Scooters
Merged your threads together and made the title a little more clear. I've also noticed that you're starting a lot of new threads for the same issues (O2 sensors). Try to keep it all in ONE thread!
Old 11-02-2010, 09:12 PM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
jets - I just did mine. I went at it from below with the car's front wheels up on ramps. It was *damn* tight getting my arms up in there far enough. If you've got Popeye forearms, forget it. I just used a 3/8" drive ratchet and 12mm (?) socket with a 2" extension. There's a frame cross-member in the way; I jammed one arm up forward of it, and one aft. Did it Saturday. The scratches on my left forearm are almost healed!
BMR is offline   Reply With Quote
