Originally Posted by stlwil
i got a rear mount out of a donar car....should i be able to move the top of this mount by hand??? its the oil filled kind,its not leaking,but i can move the top around{the bolt part} a bit by pushing it with my thumb.is this mount useable?????
the mount should have a keyway in it to keep it from spinning
I had the same problem when I put my new motor in the 95 . I was confused because the bolt kept spinning and spinning. The keyway is small, so just make sure its in there and you shouldn't have a problem
