What does the engine do when you shift from P or N into D or R? Does it clunk? If the engine mounts are bad and the "dog bone" is bad, then you should experience a noticeable jolt as it shifts. Is the 1-2 shift similar to the shift into D/R from P/N?
It's also possible that it's something inside the transmission. The Aisin A140 is a decent transmission, unlike the newer U-series clunkers that can flare and clunk even when new!
Have you ever dropped the pan, clean it and replace the strainer? (Cleanliness and fluid level accuracy are important here). Since you're having some problems (if not solved by mounts), maybe use a high mileage ATF like Valvoline MaxLife.
Main engine mounts are something I'd prefer OEM. But if you're just counting the miles before getting rid of the car, then maybe just use aftermarket mounts/dog bone like Anchor or Beck Arnley. The dog bone or the transmission mount are just rubber and those you can always use aftermarket.
Looks like all four Beck Arnley mounts are about $203+shipping before 5% rockauto's TN member discount. BTW, always use the manufacturer's catalog to find part numbers.
BECK/ARNLEY Part # 1041425 Front $86.79
BECK/ARNLEY Part # 1041520 Rear $49.79
BECK/ARNLEY Part # 1041751 torque strut "dog bone" $25.99
BECK/ARNLEY Part # 1041406 Transmission mount $40.99
Originally Posted by DaFOBulous1
1997 Toyota Camry V6 XLE
In the last few months, I have been in progress to do some maintenanca to my beloved Camry with 228K miles. (tires, struts, springs, new paint, engine mounts).
One concern I have is my transmission. It has quite a rough upshift and downshift specifically 1-2 and 2-1 especially if I have the A/C or heater on. Traffic is a nightmare since I try to be real careful. More like a clunk than anything and at times it isn't that bad.
Flushed it once and changed the oil twice within the last 20K. Still red like new. My mechanic said all of the mounts are broken but I'm not sure that would fix it.
I have been using it with my travels and logging lots of miles but I don't want to do a rebuild and it has the problem with the P0446 so I can easily see myself spend a lot more and rather just start looking for a new car.
Any suggestions is appreciated.
