Originally Posted by johnoneil
The timing was set, still weak spark, the small conector on the side of the distr is broken,(wires to the coil looked pinched or broken)... Should I replace the distr?
CHECK POWER SUPPLY TO IGNITION
COIL AND IGNITER
1. Turn ignition switch to ON.
2. Check that there is battery voltage at
ignition coil positive (+) terminal.
CHECK RESISTANCE OF IGNITION COIL
Resistance: Cold ------------------- Hot
Primary 0.36–0.55 ------------ 0.45–0.65ohm
Secondary 9.0–15.4 kohm --- 11.4–18.1 kohm
if bad, replace the ignition coil
CHECK RESISTANCE OF SIGNAL
GENERATOR (PICKUP COIL)
Resistance: Cold --------------- Hot ------------ G1 and G–125–200ohm 160–235ohm
G 2 and G–125–200ohm ----- 160–235ohm
N E and G–155–250ohm ------ 190–290ohm
If bad, replace distributor housing
CHECK AIR GAP OF DISTRIBUTOR
Air gap: 0.2–0.5 mm (0.008–0.020 in.)
Spark plug wires should have :
Maximum resistance:
25 kohm per cord
If out of spec, replace
Try another ignitor
CHECK IGT SIGNAL FROM ECM
Check wiring between ECM, distributor
and igniter, only then try another ECM.
NOTICE: ’Cold’ and “Hot’ in the following sentences ex–
press the temperature of the coils themselves. ’Cold’ is
from–10C (14F) to 50C (122F) and ’Hot’ is from
50C (122F) to 100C (212F).
If your distributor checks out, theres no need to replace it
Pickup coil resistance (Cold):
G1 and GE)
125–200ohm
G2 and G(–)
125–200ohm
NE and G(–)
155–2500
Pickup coil resistance (Hot):
G 1 and G(–)
160–235ohm
G2 and G(–)
160–235ohm
NE and G(–)
190–290ohm
If the resistance is not as specified, replace the distributor
housing assembly.
