Disconnected connector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2010, 05:18 PM   #1 (permalink)
View 93Camryx2's Photo Gallery
I have a 93 Camry XLE V6 with the hydraulic fan. The other night the power steering failed as I was going around a corner and then it overheated, blowing coolant all over. This sounds like something affecting the power steering pump. As I have been troubleshooting, I noticed a wire between the engine and the fan that was disconnected and I'm wondering if it is related. This is two wires, brown and black/yellow going into a round white plastic connector. The wires have a black tube over them, presumably to keep them from touching the block. I can't see where they come from. And ideas about where this should be plugged in and if it is related to the steering/fan failure?
93Camryx2 is offline   Reply With Quote
Old 10-26-2010, 06:44 PM   #2 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
The fans run off the power steering pump.
zppeacock is offline   Reply With Quote
Old 10-26-2010, 07:06 PM   #3 (permalink)
View camry6's Photo Gallery
I know the connector you mean, mine has it too. It is not used and is just left hanging. The cooling fan is driven by the power steering pump. The pump has 2 circuits, one for the hydraulic fan motor, the other for the power steering rack. If it lost its power steering fluid, the fan will not work. This will cause the engine to overheat. Fix your leak and you should be fine.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
The Following User Says Thank You to camry6 For This Useful Post:
93Camryx2 (10-27-2010)
Tags
hydraulic fan, power steering pump
