Gen 3 emergency flasher light bulb replacement
I need to replace the light bulb in the emergency flashers on my 94. I've done a search but can't find anything on this.
First, does anybody know what the proper bulb is?
Second, has anybody done this? I assume I will have to remove the flasher unit from the rear of the dash, or is there some way to access the unit from the front without damaging the unit or the panel? Does anybody have pictures of the rear of the flasher unit so I can see if it's screwed in to the dash from the rear or if it's clipped in?
I remember a DIY on removing the cluster panel around the dash (Toyota calls it the Cluster Finish Panel), but I have searched and can't find one. Any help with that would be gereatly appreciated. A DIY with pictures would be great.
Thanks in advance for any help.
Mike
