IS this possible? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2010, 02:33 PM   #1 (permalink)
93 Camry XLE
jets1934's Avatar
View jets1934's Photo Gallery
IS this possible?
I have a 1993 camry xle V6, recentle I've tighten my accelerator cable and I am getting way better gas mileage..is this possible..any one with any ideas..
jets1934 is offline   Reply With Quote
Old 10-29-2010, 02:51 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
where exactly did you tighten this cable and by how much? was it loose before?
Old 10-29-2010, 03:13 PM   #3 (permalink)
lurker noob
View GA-Guy's Photo Gallery
How much has your mileage improved? Any precise measurements or are you going by feel?
I assume that you have an automatic transmission. Have you noticed a difference in your shifts or in your RPM? Steadier RPM generally gives good mileage.
1996 Camry DX SXV10
"Christina" 175,000 miles and counting
2006 Corolla CE E120
"Hitomi" 58,000 miles and counting
GA-Guy is offline   Reply With Quote
Old 10-29-2010, 10:37 PM   #4 (permalink)
93 Camry XLE
jets1934's Avatar
I adjusted in the engine bay ,,tighten and reajusted the nuts..there was about 1/2 to 1 inch inch slack....there is virtually no slack now,,my mileage went from about 18mpg to now 24-25mpg same gas..same routes,,acceleration is quicker,same idle rpms
Old 10-29-2010, 10:44 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
hmm. are you sure you adjusted the accelerator cable and not the transmission kick-down cable ? they are both sort of interconnected to each other by a throttle linkage.
check this DIY thread for pics of what i'm talking about:
The Free Mod Series - Part I Quicker Transmission Shifting
Old 10-29-2010, 11:00 PM   #6 (permalink)
93 Camry XLE
jets1934's Avatar
I verified that it was the accelerator cable by revving the engine afterwards from the engine bay
