tips and tricks: installing a 1mzfe front mount,dogbone and trans strut - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2010, 03:20 PM   #1 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
hello everyone!
well i finally installed my custom polyurethane front mount and dogbone and i thought i'll give you guys some tips on installing them
front mount (removal)
to get the top bolt out i used an impact wrench with a shorth and a long extension on it... the bolt is 17mm
the other bolts are 14mm and i also used the impact gun
if your mount is in the same condition mine was (destroyed) then just slide it away... if the mount is still somewhat together you will need to lift the engine a little to get it out (see pics below on hoe to lift the engine)
(install)
the problem i had is the engine was wayy to low for me to put the mount back on so here is what you might want to do
voila!
dogbone (removal)
take out the 2 14mm bolts and get it out lol
(install)
well i had a little alignement problem so here is what i did
trans strut (removal)
i used an air ratchet to get the 2 14mm bolts on the trans and then stuck as many extensions as possible on a ratchet and applied continuous torque to break loose the 2 14mm bolts on the subframe (these are a bitch)
(install)
i'm not installing an oem trans strut, instead, i'm using a solid mount made by adam.
i reversed the bracket so that later i can only remove the horizontal botl instead of fighting the 2 bolts on the subframe
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 10-29-2010, 03:38 PM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
nice write up. this needs to be stickied. how do you like the mounts?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 10-29-2010, 03:42 PM   #3 (permalink)
redneck engineer
lemegacool's Avatar
the front mount is really nice the engine doesnt move anymore the dogbone is maybe a little bit soft in 60a urethane so i might re-do it in 80a
when you put the car in drive or reverse and hold the brake you can definitively feel new vibrations (i like them ) but its really not that bad. when you go and rev it over 1000-1200 rpm the vibration goes away!
Old 10-29-2010, 03:47 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Stickied.
'07 Honda Ruckus Big Bore
Old 10-29-2010, 04:50 PM   #5 (permalink)
Mad Scientist
now where do you get the urethane?
Camry Wagon Crew
Old 10-29-2010, 05:40 PM   #6 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
love the way you jacked the engine...most people would use the pan - big mistake...putting the weight of the engine on the pan crushes the pan seal - greatly shortening the life of the pan to block seal.
Thanks for posting the pics
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 10-29-2010, 07:19 PM   #7 (permalink)
redneck engineer
lemegacool's Avatar
thanks guys!
i got the urethane from mc master. part number for 1pound 60a:8644K26
1 pound 80a:8644K11
Old 10-29-2010, 09:00 PM   #8 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
For installing the main motor mount did you first remove the dogbone mount ?
Why not lift the engine from the oil pan with a block of wood on the jack - this would spread the force across a larger surface area.
SilverSoarer is offline   Reply With Quote
Old 10-29-2010, 09:04 PM   #9 (permalink)
doesn't matter...your greatly reducing the lifespan of your oil pan gasket. The gasket compresses, and breaks the seal.
Old 10-29-2010, 09:30 PM   #10 (permalink)
redneck engineer
lemegacool's Avatar
no left the old dogbone in...
why would i want to lift it from the oil pan? its not good plus you have way more leverage force on the spot i used
Old 10-29-2010, 10:22 PM   #11 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
So whats the point of the solid front trans mount? Just curious if it's worth it...
Chris Crash is online now   Reply With Quote
Old 10-30-2010, 11:39 AM   #12 (permalink)
redneck engineer
lemegacool's Avatar
keeps the engine from rocking backward... plus its never going to wear out
i did the test where you press the brake and give ir gas on "drive" and the engine maybe moved 1/8 of an inch
Tags
front engine mount, torque strut
