Last minute suggestions for maintenance! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2010, 01:28 PM   #1 (permalink)
View Gamble's Photo Gallery
97 camry with 190k miles.
Water pump and timing belt done at 170k miles. Cam seal,crank seal etc done at 185k miles.
New spark plugs. Wires done at 173k miles. PCV valve done just recently like 1k miles ago.
Flushed the coolant 1k miles ago. Changing the oil tonight.
What else do I need to check/change to make this car 110% reliable? I'm going to be driving my daughter around (infant) and want to make sure the car is at it's top notch.
It's also go some stupid humming from time to time on the car, but I can't find any vacuum leaks.
Gamble is offline   Reply With Quote
Old 11-01-2010, 01:44 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Service the transmission fluid. Either a drain/refill which changes only a portion of the total, or a flush job which is more complete. There are arguments on both sides as to which is better/safer.
Check the brake pads (or shoes) for wear. Replace as needed.
Check the rubber boots on the CV axles for tears. If they are, there's usually black greasy goo spewed all over; not hard to see. Replace/repair if found.
BMR is offline   Reply With Quote
Old 11-01-2010, 02:30 PM   #3 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
Motor Mounts?
Since you did wires, did you change distributer cap?
Im just thinking of issues I've had...but seems like you're pretty good to go. I would just change out:
brake fluid: every 60,000
power steering
transmission/differential.
All 3 you can do yourself pretty easily, but takes 2 to do a transmission flush. Im getting ready to change my coolant and clean throttle body right now...
and dont forget: www.**********s.com/camry
96ToyoCam164K is offline   Reply With Quote
Old 11-01-2010, 04:04 PM   #4 (permalink)
Trans was flushed. Axles are good. I'll do the brakes next.
Thanks guys.
Old 11-01-2010, 04:43 PM   #5 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
maybe the wheel bearings?
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 11-01-2010, 10:18 PM   #6 (permalink)
if you really want to test any weak links on your car, take it on a minimum 300 mile road trip. anything thats not on par will ultimately reveal itself lol
Old 11-01-2010, 11:13 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Thought of a couple more:
Check the serpentine belt and power steering belt. Replace as needed. Those are two I often replace based on mileage instead of appearance. They're cheap and easy to replace.
Check the coolant hoses; both radiator supply and return lines. Also the heater hoses. Again, I often replace these based on age instead of appearance.
Any of those failing will leave you stranded.
