p0440/0441/0446 twice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2010, 10:15 AM   #1 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
Odd series on my mothers 99 camry - here's what happened.
Car has had about 350miles on it since new engine and trans - the other day, while starting it up, the check engine light came on...usually it goes off about a second after startup, but not this time.
When I ran the codes, it said it has 6 - p0440/0441/0446/0440/0441/0446
I reset the light, and she's put 250 more miles on it, with no codes.
I've read a few things from searching that would lead me to believe this is the canister....I was hoping someone with the same experience and codes could chime in if this has happened to them.
Thanks in advance!
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 11-02-2010, 10:23 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
could be something simple as loose gas cap.
Old 11-03-2010, 04:42 PM   #3 (permalink)
sadly, no. Cap was tight, and bought about 1 year ago.
It's been 100 miles since I reset the light, and now it's back on.
but instead of listing them all twice, it only listed p0440 twice, 0441 and 0446
any ideas? thanks in advance
Old 11-03-2010, 04:52 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
oooooo Evap codes.
Well it seems there is a problem with the purge side of your EVAP system. Have you tried to check your system for leaks yet?
Old 11-03-2010, 04:56 PM   #5 (permalink)
Originally Posted by Mister_Perkins View Post
oooooo Evap codes.
well, I'm not sure what the purge side is?
Old 11-03-2010, 04:57 PM   #6 (permalink)
Thumbs up
purge side is the side that goes from the charcoal canister to the intake manifold to re-introduce the fuel vapors into the system..
Simple thing you can try to do ;
replace the line that goes from the charcoal canister to the intake manifold with a known good line. That may clear your code up
Old 11-03-2010, 04:59 PM   #7 (permalink)
thanks Mr. Perkins, I'll give it a shot.
Old 11-03-2010, 05:00 PM   #8 (permalink)
Sure
The thing about these dang evap systems is they are very sensitive. even a pin-prick hole not noticeable to the eye can cause a code to show up
Now that I looked at the EVAP system for our vehicles, instead of the charcoal canister running to the Intake Manifold, it goes through the TvV first.
Goes Charcoal Canister > TvV > Intake Manifold
PM Sent
CHARCOAL CANISTER INSPECTION
1. REMOVE CHARCOAL CANISTER
2. VISUALLY INSPECT CHARCOAL CANISTER
Look for cracks or damage.
3. CHECK FOR CLOGGED FILTER AND STUCK CHECK
VALVE
(a) Using low pressure compressed air (4.71 kPa, 48
gf/cm2, 0.68 psi), blow into port A and check that air
flows without resistance from the other ports.
(b) Blow air (4.71 kPa, 48 gf/cm, 0.68 psi) into port B
and check that air does not flow from the other ports.
If a problem is found, replace the charcoal canister.
4. CLEAN FILTER IN CANISTER
Clean the filter by blowing 294 kPa (3 kgf/cm, 43 psi)
of compressed air into port A while holding port B
closed.
NOTICE:
• Do not attempt to wash the canister.
• No activated carbon should come out.
5. REINSTALL CHARCOAL CANISTER
Old 11-24-2010, 11:20 PM   #9 (permalink)
View ontoy's Photo Gallery
Reluctantmechanic,
Hey man, was this problem ever resolved, because i'm having the same fault code on my car with just the P0440 code. I've check all 3 VSV by connecting a 9v battery to it and all 3 of them make a clicking noise, so they should be good. I've also tried to find vacuum leaks but can't find any obvious leak in the system. I've also bought a new gas cap and clean the fuel filler neck, that was my first initial fix, but code came back on.
ontoy is offline   Reply With Quote
Old 11-24-2010, 11:36 PM   #10 (permalink)
View camry6's Photo Gallery
Canada
Originally Posted by ontoy View Post
Reluctantmechanic,
I'm not sure about the Camrys, but if you SQUEEZE your gas tank FULL, it can cause liquid gas (instead of vapors) to flow out into the evap system, charcoal cannister, purge valves and lines. This will give you the purge problem codes. This was the problem with my Lexus GS 430 when I first bought it. I just stopped SQUEEZING the tank full and had to keep resetting the CEL until the liquid gasoline dried out of the system. Perfect ever since! My Lexus ES 330 is not affected by SQUEEZING the tank full, that's why I also did it to my GS. This is common with the OBD II system, '93 and older with the OBD I won't have this problem as the evap is not nearly closely monitored. You may have a leak at the tank filler neck vent as well.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 11-24-2010, 11:52 PM   #11 (permalink)
Camry6,
Thanks for your quick reply, so what your saying is never to fill the gas tank and just stop pumping before the gas dispenser release itself when its full of gas. Another thing i notice is that when i open the gas cap there is no audible pressure. how would i check a leak at the tank filler neck, from what i can see there is no obvious hole or anything like that. Actually my car is a 2000 ES300.
Old 11-25-2010, 08:08 PM   #12 (permalink)
Canada
Camry6,
When filling the tank, once the pump nozzle shuts off, just round it up to the next dollar. As for hearing pressure when removing the cap, this won't always happen. Not sure why, but I seem to get that after a long continuous drive, an hour or so. You may have a leak large enough to prevent any pressure from building in the tank. To check for leaks, its pretty much a "seek and find" situation. The gas cap and filler neck sealing surface was a good place to start. Out of curiosity, try putting a smear of petroleum jelly on the gas cap seal. This will stop any small seepage that MAY still exist around the filler neck opening.
