Originally Posted by reluctantmechanic
whew, I'm glad someone smart stepped in...thanks Mr Perkins (again!)
hehe its alright. I actually thought they were compatible and when I was changing the motor in my 95 I tried to install the 92 transmission I had sitting around and found out it wouldn't work because the NSS is different. So I changed the neutral safety switch over, and then went to wire everything up and found out that there was an extra plug on the 92 transmission thats not on the 95 harness. lol
Long story short , I had to pull the motor back out, separate the motor / transmission and hook the 95 transmission back up
The main reason I was trying to swap the transmission was because the 92 only had 86,000 miles on the motor when I rolled it. lol
Originally Posted by DallasToyo
Thanks for the response. I'm just exploring my options as to saving the newer car's engine/trans into the body of the older car.
Could both come out and be installed together in the older Camry? Plus the ECU I guess, if it's different.
Yeah, if you completely swap the entire harness from the one camry (95) to the (93) and use all the computers, you will be fine. (You can use the existing 93 motor if its in good shape) You may want to swap over the exhaust too. You could use the 93 exhaust manifold, but I'm not sure if you will throw a code or not, because on the 95 camry it has a converter right at the manifold with two oxygen sensors right in line. the 92, 93 camry have the upstream at the manifold and the downstream is past the converter.
You can use either or 5sfe motor in either situation since they are exactly the same. The only difference is the computers are different, the earlier A140E transmission (92,93) has an extra plug, which is a speed sensor which a lot of people mistake for a shift solenoid, and the exhaust is different. The stroke, bore, intake are the same, and the sensors on the motor will plug into the 92 and 95 harness.
The only stipulation in this whole process is the manual transmission should interchange between 92 93 94 95 and 96
If you are looking for a good used early gen A140E, I have a spare with 86,000 miles just collecting dust. PM Me if your interested
