2001 camry valve cover gasket sealing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2010, 09:57 PM   #1 (permalink)
Kagato91's Avatar
View Kagato91's Photo Gallery
2.2 litre.replaced the gasket but it leaks worse than the old one.need step by step instructions.I am under the impression that silicon is needed in the gasket grove on the cover and in the corners where the head is rounded for the cams,but not sure.thanks
1991 4x4 22RE 5spd 294,2xx miles.
96 4Runner wheels
ENGINE:original unrebuilt
TRANSMISSION:original w/original gears.Has new bearings and seals as of 254k.
Kagato91 is offline   Reply With Quote
Old 11-02-2010, 10:46 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
PM coming your way...
'07 Honda Ruckus Big Bore
Old 11-02-2010, 11:54 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
here you go, points of RTV application on new valve cover gasket (5s-fe).
found the image on imageshack.us ...
Old 11-03-2010, 08:48 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
When i change my valve cover, I always put a thin strip of RTV silicone around groove on my valve cover. After that I push the new gasket into the valve cover and wipe any excess rtv off, let the RTV Dry, then Tighten down. Let motor heat up to normal operating temp, then re-torque again. i think its like 15lbs or Something
If your Semi-Circular plugs are leaking, you may want to check:
General Maintenance -- 5sfe Valve cover Removal and Semi-Circular Plug Replacement
