I need to replace my oxygen sensor (the one before the front catalytic convertor) in my 95 Camry 4 cyclinder engine (not a ca model). Is this as straight forward as removing the two retaining nuts and installing a new one? The Hayes manual references a slotted socket but it appears that is not needed for the sensor I need to replace. Correct? The sensor was replaced or at least reinstalled in a new converter roughly two years ago.
NGK OR DENSO (OEM) PARTS ONLY. NO BOSCH. And yes, it's about that simple. You might have some trouble getting it loosened, but it's fairly straight forward. I don't remember any tricks off the top of my head.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Same Denso sensors (but w/o connectors) are two-three times cheaper at rockauto.com. All what you'd need to do is to transfer connector from old to new ones.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
-------------------------------------------------- FOR SALE, Sedan/Wagon parts
^ Exactly. That's what I did for my aunt's 1MZ. If you can solder, do it.
and look for it on amazon, ebay, etc.. sometimes you can get the OEM one (no splicing required) at $40-50 new just like the price of universal ones from online stores.
spray the old one with PB Blaster around the thread and let it soak for 5-10 mins before you attempt removing it.
Makes it easier too when installing / removing , like fenixus listed in the earlier post. You can get more leverage on it and more possibility of keeping it in-tact. Using a standard wrench, you risk stripping it
Originally Posted by Mike Gerber
"Is this as straight forward as removing the two retaining nuts and installing a new one?"
Yes it is. The one after the cat converter requires the wrench they refer to in your Haynes manual.
That link is a gray area. I'd remove it as it risks Toyota shutting down this site, but I'm not going to send out infractions for it.
Thanks for all the help. Replaced the sensor today. Seem to improve the acceleration. I am surprised that a broken wire on the upper oxygen sensor didn't cause the CEL to come on.
