Originally Posted by Spankedmonkey
I'm a Noobie so bear with me.
Ok I have the Pioneer AVIC-F900BT pretty much wired in my 96' Camry Wagon except I need help locating the VSS wire, and reverse wire. Also the stock antenna plug has two separate jacks whereas the AVIC only has one antenna input, and the antenna is not raising. How do I install this one?
Along with this my XM HD radio is not tuning to stations. What gives here?
Everything else is functioning fine; Ipod, DVD, display, FM radio, bluetooth, contact upload, etc... I've done the bypass and the GPS is functional. Thanks for any info.!
The Reverse is located on top of the transmission.
If its a manual, its located to a small switch. If its an automatic, its located as part of the Neutral Safety Switch. Speed Sensor is also located on the transmission as well.
Your FSM Should indicate exactly where the VSS is
Not sure about the other crap though.. never owned one of those before. Sounds expensive .lol
