Oil for my Camry 1998 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2010, 11:28 PM   #1 (permalink)
View jaguar2009's Photo Gallery
3rd Generation Oil for my Camry 1998
I have a Camry 1998 with 200 000 milles, and the weather in my city is 95º F
What type of OIL can i buy....?
Thanks
jaguar2009 is offline   Reply With Quote
Old 11-05-2010, 11:57 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
In the US the Gen4 specified oils are 5W-30 and 10W-30. I'd say Motorcraft Synthetic Blend 10W-30 should work fine. We find these at the local Walmart at about the same price as the "dino" oils.
Dealers here sometimes sell 10W-40 for "older" engines. However, I'd use Valvoline MaxLife 10W-30 instead.
If a xW-40 weight is specified in your area, or if your engine is consuming oil, then Mobil-1 0W-40 would be an excellent synthetic oil to use.
Use a good filter, like Purolator PureOne.
See message #1619697 10/04/09 12:00AM SuperBusa:
http://www.bobistheoilguy.com/forums...Number=1619451
I wouldn't use the AC UltraGuard even if it has less differential pressure. I don't think it filters very well.
Thanks
The Following User Says Thank You to JohnGD For This Useful Post:
jaguar2009 (11-08-2010)
Old 11-06-2010, 05:21 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
depending on what type of oil you are used to run in the car (conventional vs synthetic) you might want to try the Mobil1 0W-30 Advanced Economy instead of regular 5W-30 or 10W-30, unless car consumes oil, then go for 40 weight or High Mileage version as suggested above.
just remember that if your car used to run dino oils only (conventional) it helps to mask some gasket/seals problems and when you switch to thinner synthetic oils (particle size makes the difference) the seals might start seeping or leaking. be careful.
0W-30 is fully compatible with 5W-30 (which supersedes the 10W-30).
The Following User Says Thank You to fenixus For This Useful Post:
Old 11-08-2010, 07:38 AM   #4 (permalink)
Thanks, your information is goog. I will use 10-W30 Oil
