Timing Belt or Transmission? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2010, 04:33 PM   #1 (permalink)
99 5SFE Camry
View dynasty's Photo Gallery
Hi guys, I own a 99 4-cyl Automatic Camry with 107k miles on it. Just the other day when I started up my car, I noticed the check engine light(gosh dangit) was glowing. So I'm wondering what the heck is wrong with it...here are the symptoms I have experienced:
At Idle: RPM wobbles underneath 1,000 and doesn't pass 1,000. (It used to be steady)
When I turn the engine on: It takes a second/half-a-second longer for my motor to start while it used to start just fine.
While driving: At certain amounts of acceleration it takes longer for the power to kick in. RPM goes up just fine but no true acceleration happening until 1-3 seconds later. Oh and sometimes when I'm feathering the throttle to decelerate at speeds greater than 40 mph it feels like the trans. kicks sometimes.(Transmission is lagging in a way, or timing is off or something like that...)
__________________________________________________ ________________________________
It would be very helpful if you guys could make some assumptions as to what is wrong, and if possible, tell me how much you think this would cost me at a repair shop.
Thanks for reading and for the help in advance!
dynasty is offline   Reply With Quote
Old 11-06-2010, 04:42 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
get the trouble codes scanned for free at local autozone or advance auto and post them all here.
The Following User Says Thank You to fenixus For This Useful Post:
dynasty (11-06-2010)
Old 11-06-2010, 04:46 PM   #3 (permalink)
99 5SFE Camry
Alright, I'll post those up as soon as I can, I didn't know advanced auto parts or auto zone would do that for free!
Old 11-06-2010, 04:49 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
yes they do obd2 scanning for free
Old 11-06-2010, 06:09 PM   #5 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
Hi guys, I own a 99 4-cyl Automatic Camry with 107k^
boy, thats low mileage...has the belt ever been done?
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 11-06-2010, 06:12 PM   #6 (permalink)
99 5SFE Camry
@reluctantmechanic: No, I haven't replaced the belt for this car, and the belt should be good
Ok! So they scanned it and it said a bad MAP sensor. So we checked it and the wire was unplugged haha. Plugged it back in and within 20 seconds idle was smooth again and the drive home was very promising. But i should drive it around for at least a days worth and then reset the CEL if it hasn't gone away by then.
I have no codes to show because their printer was out for today...
Thank you very much for the advice fenixus!!!
you to reluctant (:
It's amazing how simple the solution turned out to be. (hopefully, this will fix it!)
Consider this thread inactive unless I start complaining again heh
Old 11-06-2010, 06:16 PM   #7 (permalink)
Gameroom cash: $814501
View zythr's Photo Gallery
Sounds like your timing belt is going. If you have a delay when you turn the key (ie like something is snagged) before the starter engages and the engine starts, can be a symptom of a failing T-belt
zythr is offline   Reply With Quote
Old 11-06-2010, 06:24 PM   #8 (permalink)
99 5SFE Camry
I'll make sure to pay attention for that the next couple times I start it up
Old 11-06-2010, 06:31 PM   #9 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
If your timing belt has never been replaced, you're on borrowed time.
71Corolla is offline   Reply With Quote
Old 11-06-2010, 06:32 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
glad it helped
those cars can really tell you what hurts them if you know how to make them speak
and I agree with other posters, t-belt (and water pump most likely) is due to replacement SOON. they are scheduled to be replaced (together) every 90k miles, but they can last like 120k miles (it's a stretch, like 71corolla said, driving in a borrowed time). think about it to avoid unpleasant surprise in near future.
Old 11-06-2010, 07:31 PM   #11 (permalink)
timing belts don't feel like they "snag" they break or jump time. The slow start might be your belt having jumped time, making it harder for your car to run.
a slow start would make me think battery, starter, fuel problem,. but in this case, the code is going to tell us everything.
Old 11-06-2010, 11:57 PM   #12 (permalink)
99 5SFE Camry
Would replacing the t-belt and water pump be a job for a repair shop to do? And, How much money do you think that would cost me?
Thanks for the input guys, I'll refer back to this thread if this MAP sensor isn't the only problem
Old 11-07-2010, 05:07 AM   #13 (permalink)
this is a pretty easy diy - there is a video tutorial called "toyotarepairvideos.com" I think for 14 bucks, you can watch them do one...I recently did my moms car, and the video was very useful.
I think with belt, waterpump, tensinor, maybe the cam seals? 100-200 bucks.
The Following User Says Thank You to reluctantmechanic For This Useful Post:
dynasty (11-07-2010)
Old 11-07-2010, 11:39 AM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
there is a nice timing kit for 98-01 camry 2.2L on ebay.
another one which is great is sold by Rockauto.com:
http://www.rockauto.com/catalog/moreinfo.php?pk=1798460
at $153
local shop charges from 3.5hrs labor up to 5.9hrs labor on timing job depending if they do the oil pump seals/gaskets or not. hourly rate here is like $60/hr cheapest.
Check the Camry FAQ section in stickies, there is a few Timing belt DIY's for our cars. if you have time and tools (3/8'' metric socket sets, torque wrenches, etc.) then go for it. will take a few hours though
you may need to borrow a 1/2'' breaker bar and harmonic balancer puller from local Autozone.
Old 11-07-2010, 12:15 PM   #15 (permalink)
99 5SFE Camry
Hmmm ok, im attending college right now but I think I will try to do this DIY over thanksgiving break which is coming up real soon. It looks like if I did the DIY successfully it would cost less than taking to a shop most likely right?
