What is the best way to get the new camshaft and crankshaft seal in?
I'm putting a new timing belt on a '99 camry 5S-FE auto. In chase you wanted to know it broke (teeth came off around crank gear). The car has 130,xxx miles on it. I think that is one of the longest lasting ones on here.
I would like to put new seals in, and in the kit I also got the oil pump seal. The camshaft seal looks like it leaks a little and the oil and crank aren't leaking. I don't know if it is good to leave well enough along, or as long as I'm in there replace what I can.
I plan to pull the oil pump cover off and replace the shaft seal and what they call and o-ring, it is more of a cover seal. I have the camshaft seal in and it when OK. I've done this on a 3S-FE, the camshaft seal is hard to hammer in because it sits behind the strut tower when the engine is in the car.
I've used two methods to get the seals out in the past. If the seal is big enough I've ran sheet metal screws into it and pulled it out with those. I've also carefully used a screwdriver to work the seal out. This seems to work fine.
The hard part is to get the seal back in. I've installed about 6 seals by using a hammer and 1/4" ratchet extension and slowly pounding around the outside to evenly drive it. Or I've used a large socket a little smaller than the seal and hammer or pry it in. The problem I'm having is I oil or grease it, but the outter parts of the seal seem to catch a little and rolls out a little bit. The seal still looks good but I want to get it in there a little better. Is there a better method?
