Originally Posted by jgaray09
Is there an easy way to check fuel pressure on this car? I never learned how to check fuel pressure. do i need any tools that i can get at the local parts store?
Any ideas?
Thanks for your time.
Check the following before checking fuel pressure:
• Fusible link
• Fuses (AM2 30A, EFI 15A, IGN 7.5A)
• EFI main relay (You've already checked this)
• Fuel pump (Test Below)
• Wiring connections (Wiggle the wires make sure connections are tight to fuel pump, injectors)
Fuel Pump Test:
connect terminals +B and FP of the data
link connector 1 using a wire.
Turn ignition on. (DO NOT START MOTOR)
Check that there is pressure in the hose from the fuel
filter.
HINT: At this time, you will hear fuel return noise.
Turn ignition off
Remove the wire from +B and FP
If you cannot feel fuel pressure or hear fuel pump, go to next step
To check the fuel pressure, you will need a fuel pressure gauge (available at your parts store for rent). You will need a Gauge with a Banjo Adapter.
Loosen the bolt on the fuel filter, remove the banjo bolt, remove the line that runs to the fuel rail.
Install your Gauge with Banjo fitting.
Re-install banjo bolt (Leave the line to fuel rail disconnected)
Connect terminals +B and FP of the data
link connector 1 once again.
Turn ignition on.
Monitor fuel pressure
Fuel pressure:
265 – 304 kPa (38 – 44 psi)
If pressure is high, replace the fuel pressure regulator.
If pressure is low, check the following parts:
• Fuel hoses and connections
• Fuel pump
• Fuel filter
• Fuel pressure regulator
