A few days ago it was working, when I press the button the cruise light doesn't come on and it doesn't engage. What would cause the cruise control not to work if all the fuses are good? what should i check?
thanks
btw I have a 99 camry le i4
thanks
check the electrical connector - it sits very close to under the battery, and it might have popped out, or even corroded.
The module might have gone bad - but I'm not sure how one would test for that.
thanks
If the cruise control unit / Computer are the same and you find out that one are bad .. I have the cruise control unit and computer from a 3rd gen camry
I would check the connectors like reluctant said, Make sure your unit is getting power using a test light or multimeter, double check the grounds using a multimeter.
Things to check: Cruise Control Electronic Control Unit (CC ECU), actuator, cruise control cable, speed sensor, cruise control switch, stoplight switch, park/neutral switch and related wiring.
__________________ It worked fine until I fixed it!
lol i feel like a dumbass :P I figured it had to do with something I might have unplugged when i was trying to help the one guy with his shift lock solenoid
