I had the same problem and I was unable to siphon it out. I ended up with disconnecting a pipe from fuel filter, putting a hose on it, another end of hose was in the bottle, and applying 12V directly to fuel pump's connector.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
-------------------------------------------------- FOR SALE, Sedan/Wagon parts
there is a fuel line connection in front of the driver's side rear tire. disconnect that and the fuel will siphon out since the connection is lower than the tank. found this out by mistake when replacing a fuel line.
I've always found that drilling a 1/2" Hole at the bottom and tapping a 1/2" Bolt with rubber o-ring works pretty good after the tank is already drained for future service.
What you need to do first is get the tank off. Take out the back seat and unplug /remove the plug / fuel pump assembly that connects to the top of the tank.
Remove filler neck lines first Place a floor jack under the tank with a wide board in the center of the tank put some pressure on it with the jack.
Remove the straps and let the jack down a little bit. Once the tank drops down enough to see where the pump and wires are able to be seen visually, disconnect them. Drop the tank the rest of the way. Get funnel with filter, and drain the gas from the tank to a designated fuel collection area.
When ready to re-install, simple connect lines on top, connect harness to pump, strap it in place, connect your filler lines and done
I would caution anyone against drilling a hole into a gas tank, empty or not. It is almost impossible to remove the fumes from a gas tank unless you steam clean it, or let it sit for a long time in open air. It is unlikely, but possible, that a spark from drilling will ignite the fumes.
BTW, my '87 has a drain plug, generation 3 Camry's don't seem to have one, at least mine didn't.
This.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
True, its usually safer to fill the tank with water before servicing the tank
