Its LEAKING!! :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2010, 08:32 PM   #1 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Its LEAKING!! :(
Oil is leaking from a part of the engine that Im not familiar with AT ALL!
OK... its on the drivers side. It is directly under the radiator hose. It is very close and to the right (standing infront of the car) of the exhaust manifold. It SEEMS to be attached to the Starter. There is a thin metal plate that is attached at the end of this thing and again, its very close to the exhaust manifold. The oil is pouring out of that area!
Its coming out between that thin metal plate and dumping oil around that whole engine area!!!
HELLLLLP!
What is it!?
1992 Camry I-4 with 145K miles
Deadly Sushi is offline   Reply With Quote
Old 11-08-2010, 09:08 PM   #2 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
HELLLLLP!
What is it!?
deadly that plate covers the componets that connect your trans to the engine - and beneath it are two seals - your main engine seal, and your transmission shaft seal
From what you are describing, it sounds like this leak is "higher up" on the engine? maybe your valve cover is leaking down, and dripping from the between the two?
could you tell us your year, engine and mileage?
thanks
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
The Following User Says Thank You to reluctantmechanic For This Useful Post:
Deadly Sushi (11-08-2010)
Old 11-08-2010, 09:15 PM   #3 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
take a picture of it.. you will have an instant answer
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
The Following User Says Thank You to lemegacool For This Useful Post:
Old 11-08-2010, 09:32 PM   #4 (permalink)
My main engine seal???
I have a 1996 2.2L LE with about 180K miles.
I just bought it last week! It was owned by a family on welfare and it looks like they havent changed the oil in a loooooooong time.
I shall take a photo of it and then post it tomorrow. By oil seems to have been flying directly out of that cover and splattering (yes... splattering) all around the area... plus the oil poured down that area and left a nice puddle of oil on the pavement.
How does one FIX this main engine seal / trans shaft gasket thingy?
Old 11-08-2010, 09:39 PM   #5 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
With lots of time, unfortunately.
SexieWASD is offline   Reply With Quote
Old 11-08-2010, 09:43 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Try to clean up the engine bay. It will help spot exactly where the leak is coming from.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
Old 11-08-2010, 09:53 PM   #7 (permalink)
The trans seal is easier...by a little. The main engine seal is a little more involved, you have to take the transmission off to get to both - not fun, but doable with the right tools. Once the trans is off, you have to take the ring gear off the flywheel, and then remove the flywheel - with the engine in the car, these are not easy things to do. If it's the trans seal, you just remove the trans, and remove the torque converter, and it's right there.
I don't believe these seal are very expensive - if you are going to do this job, you should do the main engine seal, the trans seal, and the axle seals all at once.
These seals, when old, when exposed to freezing temps, can just fail - most likely the previous family wasn't trying to hide anything (hopefully).
But don't get ahead of yourself - main seals seldom "pour out" more like a drip...take a picture and point to where you think it's coming out, and try and make sure it's oil, and not grease (from the axles), trans fluid, or something else. I'm hoping one of your trans lines got nicked and is leaking - could look like oil, and an easy fix.
Old 11-08-2010, 11:04 PM   #8 (permalink)
Dear GOD!!!!
How much do these seals? How do I do this?? I dont think I COULD do it. I dont think I have the right tools to take a trans off. You need a lift right?
And if I pay for someone to do this I might as well just sell the thing. This is HORRIBLE!!!!! I shall take a photo tomorrow.
ANyone care to buy a 96 Camry? *sigh*
Old 11-09-2010, 06:18 PM   #9 (permalink)
here is the photo as promised! You can see the fluid / oil came from the shield and then dripped down. I was Sea Foaming the engine and clearing out the carbon crap while reving the engine at 3500 RPMs. THEN I saw all the smoke from the engine area. It SEEMS like it tossed a LOT of fluid from that area and then dribbled down the engine area.
Old 11-09-2010, 06:29 PM   #10 (permalink)
when you say "tossing" the first thing that comes to mind is, the main engine seal is leaking, the oil is leaking onto the flywheel, and as the flywheel spins, the oil is sent in every direction.
I don't want to say main seal yet (because of the work required to fix it) - if you have time, and it's warm enough, buy some engine degreaser, spray that area, and clean off as much oil as you can...I'm hoping you have a leak right above that area, in your valve cover...
Old 11-09-2010, 06:32 PM   #11 (permalink)
I used engine degreaser the day before and that area had no oil..... unil I did what i did.
Old 11-09-2010, 06:39 PM   #12 (permalink)
Well, that leans me towards main seal...we have very smart, experienced guys here - I'm hoping someone else will tell me I'm wrong...
I just thought of something...
...if you remove the starter (I believe 2 14mm bolts, and two or three electrical connections, and remove the airbox) you'll have a very good look at your ring gear, and might be able to flash a light or mirror into the starter hole to see what's going on. Starters are very easy to remove and you'll have a good view of the area right where it's leaking.
Old 11-09-2010, 06:43 PM   #13 (permalink)
redneck engineer
lemegacool's Avatar
i'm not experienced but i would also say rear main seal...
you could maybe check to see if there is anybody from tn near you that could help you replacing it...
Old 11-09-2010, 06:51 PM   #14 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Looks like a real seal to me as of now. do you have a picture of the Head / Transmission together? Could be something else
Reluctant has a great idea with removing the starter.
If you remove the starter and its covered in motor oil that will also be a direct indication its your rear main seal. Takes 2 minutes to remove it . just make sure you disconnect your battery before removing it
Old 11-09-2010, 06:57 PM   #15 (permalink)
You can diy this...and I would suggest removing the engine to do it.
You'll need:
Lots of space
an engine hoist (119bucks, or borrow one)
Torque wrench (pep boys does free tool rentals)
basic metric sockets, and long sleeve metric sockets (10mm-19mm mostly)
an engine leveler (again, a rental from pep boys)
all the seals, and the timing belt while you're at it.
I think, all told, with all the seals, tools, belts, etc, you might spend 400 diy - there might be a local toyota speciality shop that can do this job much cheaper, because they have the tools, and have dozens and dozens of them (saving time and money).
You could do this with the engine in the car - without a lift, or a trans jack, this approach usually will cost you more time than if you just pulled the engine.
Taking the engine out isn't too bad - sounds hard, but easier than a head job (imho)
