Hi,
I've been searching though this forum for quite some time now and would appreciate some advice/troubleshooting on my current problem. If I missed anything please let me know. Sorry for the long post. ('95 Camry LE 2.2L 5S-FE)
Recently, I just had a bad "head gasket" as I kept overheating the engine. I knew I needed a new "Rear main seal" and "torque converter seal" (from a prior safety inspection several years ago). So, I decided to pull the engine out and work on it myself at my girlfriends farm. This took some time for only myself, as it is very dusty there. Since, I had previously had a bad oil leak (bad o-ring on pump), which I repaired this spring myself, the engine was in filthy shape, so it took me longer as I cleaned all the parts up as I disassembled and reassembled the engine, while replacing the head gasket. (I will note this was my first engine "Rebuild" and I did it myself with only reading this forum and a ninja manual on the camry.) I also cleaned off as much carbon deposits I could see and replaced many hoses. Check parts also like the distributor and such.
Next, I went to deal with the Rear seal & torque converter seal by disconnecting the transmission. I followed the manual to the tee and never had any problems with the rear main seal. However, I could find absolutely NO info on the torque converter seal and replacing it. So I did my best to figure out how to do it. I finally ended up removing the trans pump disassembling it and "pushing out the old seal with a screwdriver. Then tapping in a new seal. Everything seemed to go ok, accept when I pulled out the pump I did seem to slightly bump (or move off kilter) the Direct Clutch (top/first pack) - however I made sure it was seated back when I re-installed the pump. Mind you, I had just moved it maybe 1/4" off and I just pushed it back and it fell into place. I made sure the torque converter was pushed as far into the trany as I could get it, and I even put extra fluid in it in case any drained out. It was taken off with the transmission, but removed to take out the pump.
Everything went ok as I reassembled and reinstalled the engine. However, this was a long process for me as I had to use a Skid Steer (like a bobcat) to remove and install the engine. Like I said, on a farm.
Anyways, after I started the engine it ran perfectly! I took the car out for quick slow drive down the street and the transmission started to die on the way back. I would go, then stop, turn off car, wait, then I could go a couple blocks more. Looking back 3rd was slipping badly. I originally thought I had put the oil pump in wrong or assembled it to tight, but after many days of troubleshooting the transmission I build a pressure tester and figured out how to test the oil pressure. It was ok. In the process of troubleshooting I also drained fluid several times, replaced trans filter. Looked for code, ect. One main thing tho.. I had NO REVERSE now. But after changing all the fluids and futzing with it, the car would now drive forward and not die. So I am left here and these are my test results so far.
I have NO REVERSE unless the engine/fluid is cold or has been sitting a long time, then I can just slightly get it to go backwards.
Troubleshooting results:
Lock-up & shift-down:
O/D on:
R (R) - Will only go slightly in reverse after engine has set and fluids are cold/thick. After warm-up, rev all you want however, it isn’t going anywhere.
L (1) - Stays in 1st gear no matter what. Engine brakes excellently.
Max RPM = beginning “Red-line” if held long enough. [within specs]
2nd (1-2) - lockup at (39mph). [within specs]
2nd (2) - Engine breaks excellently. [within specs]
D (2-3) -
lockup – doesn’t happen full throttle
Will shift into 3rd after accelerator peddle let up let up about half way.
D (3) - Slips into 2nd too easily when given some throttle.
O/D(4) Downshifts to 3rd at highways speeds and slips from 3rd to 2nd when,
0 throttle and O/D button turned OFF, then accelerator pressed slightly. Seems that it never really is locking up into O/D. Very hard to tell if ever in O/D however see below.
Manual shift into 2nd from 3rd (3-2) - downshifts at (68 mph).
Manual shift into 1st from 2nd (2-1) – downshifts at (33 mph).
Stays in 3rd @ 4000 rpm 70 mph in cruise control, no O/D seems to happen.
O/D will downshift to 3rd approx 2250 rpm (no throttle, then some). Happened 1 or 2 times.
Solenoid Disconnected Test:
1 - 1st gear works fine.
2 - 3rd gear seems to drive ok.
D - O/D ???. (Appears to actually be in 3rd as 4000 rpm at 70 mph).
R - R doesn’t move!
P - Park works fine.
Hydraulic Pressure Test: [all within specs]
Drive (D)
Idle pressure – (52-54 psi)
Stall pressure – (120 psi)
Reverse (R)
Idle - (96-102 psi)
Stall - (200+ psi)
RPM Test:
[R Stall bad]
Drive (D)
Idle - (750 rpm)
Stall - (2500 rpm)
Reverse (R)
Idle - (850-900 rpm)
Stall - (5000+ rpm)
Bump Test:
Drive (D) >1.2s (less than 1.2 seconds.)
Reverse (R) Not really a bump at all but if I try very carefully I can feel barley noticeable nudge. >1.5s (less than 1.5 seconds.)
I have tried changing the throttle cable, and 3rd still won't lockup at full throttle. I get no codes (I even did a "Test Mode" ECU diag). Dex II-III / Valvoline Maxlife ATF in currently, and it seems better with that, than using the crappy generic Dex II I had started with. Did have a lot of metal shavings when dropped pan. Most were magnetic/steal, but there were a fair number of light brass colored ones in the drained fluid too.
My diagnosis:
Probable Cause:
Since Reverse not working, 3rd slips, and O/D issue, only thing that seems to be in common is the Direct Clutch.
Bad part: Direct Clutch (C2) - a plate or clutch in there somewhere?
Would anyone know if this sound correct, or are there 2 thing I should have to replace? Also, any idea's of what inside (plates) that will need replacement? I would like to buy the parts (local or online) before I remove the transmission if possible. Make a "best guess" of what I need since I am going to get some help this time since it is now cold here in Wisconsin, and I don't want to remove the engine (as that really is not as easy as some people have said it was). I broke other things and had to replace them/fix them when doing that on an older car.
Thanks much!
Oxygen
