Originally Posted by coolguy004
Have done a power wash and no visible leaks..I topped off about 1/2 a quart yesterday to be on the safer side.
Which area do you want me to clean and check?
Well in your first post you said you saw oil around / on the VSS. I would start cleaning there first. Also, Have you checked your distributor seal ? There is a seal on the distributor shaft that connects to the motor
^^^ That's if your car has a distributor. If it has coil packs, then you will not have the above possibility
