2001 slight surging when cold
2001 2.2L - 78K miles....I've noticed when first starting cold...engine RPM seems higher than I would expect it to be - is revving fairly high.....but does come down to normal after a bit...and car seems to take longer than I would expect for temp to come up to normal....if I take off while temp gauge is still in the cold range...the engine seems to surge up and down somewhat...not to any great extent that it is affecting the operation of the car...but enough so you can feel that something is going on...then once temp gauge reaches normal...no problem. Any thoughts on this? Coolant Temp sensor perhaps? They're cheap so I might just throw a new one in and see what happens. Also figured I'd give the IAC a good cleaning. Thanks for any thoughts.
