Rad fans kicking late - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2010, 09:09 PM   #1 (permalink)
View mbba's Photo Gallery
hi all, i have camry 96 and have a problem that my rad fans dont go on only when the temp. reading is above 3/4 then it comes on.... i changed the temp switch below on the rad but still same, help needed...thanks
mbba is offline   Reply With Quote
Old 11-10-2010, 11:40 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
SEARCH around the forums.... common problem. If you can't find any answers, let me know. to TN!
'07 Honda Ruckus Big Bore
Old 11-10-2010, 11:42 PM   #3 (permalink)
View ULAWE's Photo Gallery
I had the same problem! It caused my engine to overheat like hell. I will post pics soon on how to make them both spin when the engine is turned on.
Step 1:
turn off the engine go under the hood.
Step 2:
Driver side radiator should have this power connection
Step 3:
Disconnect that, and turn the car on without the engaging the engine
wow my hand is big lol
ULAWE is offline   Reply With Quote
Old 11-11-2010, 04:40 PM   #4 (permalink)
my fans spin but spins to late when the guage is above 3/4 , if in highway then its always half but when i stop in stop sign then starts climbing to 3/4 then stops there when the fan kicks...
Old 11-11-2010, 04:56 PM   #5 (permalink)
Freakin Scooters
ULAWE... that's just sidestepping the problem.
MBBA... Searching SIMPLE terms is usually what helps. I just searched the word "fans" and got some hits. Take a look. (You might also want to try other words like "overheat".)
Solara Radiator Fans
Temperature Gauge Rises??? Please respond
Only high speed radaitor fan working
Overheating: becoming an issue
IMO, this sounds like a sensor/electrical problem. But in this case it's beyond my skills to really call it anything.
Old 11-12-2010, 08:48 AM   #6 (permalink)
i think i found the problem of fan running late temp. above 3/4 guage, but problem i need solution ...... when i run the car at normal temp thats 1/2, stoped and checked the radiator heat with my hand , the upper was very hot and the lower was hot not that much like upper.....that means the temp switch is not starting untill the lower is real hot meaning by that time the temp in upper rad is already near boiling 3/4..... any ideas please, before i start changing the rad....thanks all
Old 11-12-2010, 10:08 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
sounds like a thermostat problem. I would suggest replacing it with a new OEM one with new gasket.
I think the difference in coolant temperature between upper and lower hose should be small, maybe 10F degrees or even less once the thermostat is opened fully...
Old 11-22-2010, 09:14 AM   #8 (permalink)
thanks to all, i got my problem fixed, it was the thermostat , i removed it and fixed the housing without the thermostat and temp was normal and the fans kick at 1/2 guage.....i hope there is no problem driving with out the thermostat,is there?
Old 11-22-2010, 09:22 AM   #9 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
LOL .. dude , put that thermostat in there!
Old 11-22-2010, 09:24 AM   #10 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Yeahhhhh without the tstat it will never get to normal operating temps. I have this problem on my 94 right now, tstat is either stuck open or missing.
Gotta fix it...one day...
Chris Crash is online now   Reply With Quote
Old 11-22-2010, 09:29 AM   #11 (permalink)
you getting crappy fuel mileage?
Old 11-22-2010, 09:57 AM   #12 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
What's the average air temp in the UAE? Do you ever need the heater?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-22-2010, 10:04 AM   #13 (permalink)
never use heater here
Old 11-22-2010, 10:55 AM   #14 (permalink)
That's what I thought. You don't need the thermostat, but I'd replace it anyway.
Old 11-22-2010, 11:00 AM   #15 (permalink)
running a vehicle without a thermostat can cause a hot spot in the coolant system that can lead to a blown head gasket.
