overfilled oil,drove 10m,thick smoke,drained but.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2010, 09:32 PM   #1 (permalink)
View lotsohsmoke's Photo Gallery
i got a 1993 v6 auto camry and I changed my oil today went up the block and bad smoke started coming out like no more than 30 seconds of driving. I thought I may have spilt some i drove about 3-4 miles and stopped to check. I overfilled not sure by how much considering all i had available was 4 quarts to begin with.
It seemed to stop momentarily at stand still, as well as when i wasn't getting on it. but the moment i start going up a hill or need to accelerate to change lanes clouds and clouds of smoke.
I got back home 3-4 more miles dropped the oil and refilled this time with only 3 qts as my dip stick cant get a good read currently. I let it idle to see what happened and the smoke is still there like when i first changed it.
I'm thinkin maybe i got some slighty touchin the cams or pistons? into the exhast? the exhaust tip has an oily residue. Im thinkin that if there is oil in the exhast system ill have to burn it off right?
The smoke color is not blue at all its a thick white when hard accel.
I dont think i drove it long enough to do any serious damamge but then again im here asking what could it be or is my conclusion good?
lotsohsmoke is offline   Reply With Quote
Old 11-10-2010, 09:58 PM   #2 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
The v6 holds 5 quarts of oil not 3 or 4. Did it smoke at all before you changed? What weight did you put in?
zppeacock is offline   Reply With Quote
Old 11-10-2010, 10:14 PM   #3 (permalink)
5w40 and now 5w30 ....and no smoke ever and ive had it like 6 six years. thats why i dont understand. also there is no mixture of oil and coolant in either oil pan or radiator.
i did however just go down there started it about ten minutes ago and lifted the dip stick for the oil and im not sure if it normally dos this but it was spittin oil out
Old 11-10-2010, 10:18 PM   #4 (permalink)
Sounds like its way over full. What does your dip stick say? They only hold 5 quarts.
Old 11-10-2010, 10:31 PM   #5 (permalink)
i know its not giving me a correct reading but it says 3-4 inches over full. and it ticks like is low on oil when i had overfilled it or even close to 5 quarts no tick.(you know what im talkin about like i konw if i add another quart or so it would stop) and Originally when i changed it the first time i only had available was four qaurts but i know refill shouldnt be 5 quarts it should be alil less cuz some oil stays or sits . so im told . when i drained it this second time i only put like 2-3 in it.
Im suppose to be leaving in the morning for houston tx which sucks..
Old 11-10-2010, 10:40 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Did you remember to drain the oil before refilling it?
Zembonez is offline   Reply With Quote
Old 11-10-2010, 10:43 PM   #7 (permalink)
yes i remembered to drain the oil ..dude....
i need answers bud not questions ...
Old 11-10-2010, 10:46 PM   #8 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Yeah but ya gotta keep a sense of humor through the toughest times man. You know I was only messing with ya.
All we can really do here is guess. That is an odd deal. Hope ya get it solved soon.
Old 11-10-2010, 10:57 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
but seriously, lotsohsmoke you under-filled it the first time and even more the second time. your engine needs 5qts of oil after drain, period, as said above... unless ... read at the end.
I think running 1qt low on oil might have screwed up something, and definitely running 2qts below level screwed up some more.
the color of smoke looks like you are burning the coolant? have you checked the coolant level to make sure it doesn't get low now? did you overheat the engine by any chance?
how much oil can you drain out? ever tried to estimate it? maybe your engine is sludged to hell and you drain out only like 1qt of oil and then you keep refilling it with 4qts (Or whatever amount you used to put in it)? just a thought...
what happened to your oil dipstick that it is now inaccurate? dipstick from a different engine or what? it's not good.
Old 11-10-2010, 11:50 PM   #10 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $581920
View IronNam's Photo Gallery
rings, exh valve seals, or something....
oil at the exhaust tip?
white smoke not blue... isn't that coolant?
the smoke smells like oil right?
what kind of oil?
what kind of filter?
94Hilux-XCab-22RE-W58-8"V6
IronNam is offline   Reply With Quote
Old 11-11-2010, 12:08 AM   #11 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Sounds like you have way too much oil in the engine. When that happens, the oil can go through PCV system and hence the smoke. The dipstick doesn't lie (unless you didn't put it in correctly) so if its way above the full mark, you have too much oil in the engine.
71Corolla is offline   Reply With Quote
Old 11-11-2010, 05:58 AM   #12 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
agree. The extra oil can damage some sensors - first that come to mind are the 02 sensors...I'm surprised your CEL hasn't come on...and I was always under the impression that excessive oil burned off as blue, not white - white would make me thing head gasket...but if it was, you'd know by the smell.
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 11-11-2010, 06:18 AM   #13 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
Drain the oil again, and with the drain plug out, and it empty, check the oil level on the stick. Something may be blocking the drain hole in the pan.
SexieWASD is offline   Reply With Quote
Old 11-11-2010, 06:35 AM   #14 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
You dont check the oil level with the car on. With the engine turned off for a good 10 min check the dipstick a couple times.
Its IMPOSSIBLE to check oil level with the engine on.
Are you sure you didn't accidentally pour something else (windshield washer fluid or coolant) into the crankcase? And are you sure you drained the oil and not the transmission fluid?
carsrus is offline   Reply With Quote
Old 11-11-2010, 08:25 AM   #15 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
" Think with your dipstick JIMMY "
The Following User Says Thank You to Mister_Perkins For This Useful Post:
LynchburgCSI (11-11-2010)
Tags
exhaust, oil, overfill, smoke
