URGENT! RPM & Speedometer not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2010, 11:39 PM   #1 (permalink)
View ULAWE's Photo Gallery
3rd Generation URGENT! RPM & Speedometer not working
My RPM & Speed-o-meter no longer works after I had the oil changed, and painted under the hood.
No matter how much I rev it, and drive it. It both stays to 0. Could it be a blown fuse? can someone tell me how to troubleshoot. Thanks!
Vehicle is a 1993 Camry LE 4cyl 5SFE
ULAWE is offline   Reply With Quote
Old 11-11-2010, 12:02 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
I see your airbag light is on, does it stay that way? Checked fuses? Did you disconnect anything when you were painting? What kind of painting did you do?
71Corolla is offline   Reply With Quote
Old 11-11-2010, 12:07 AM   #3 (permalink)
I fixed the RPM by hitting the side of the cluster. Yes it worked, but the speedometer is not working still. Painting is in my other thread, and I only removed some wires but put them back. Yes the AirBag light has been on for over 8 years.
Old 11-11-2010, 08:28 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Did you disconnect the VSS ? You got the RPM working again .. the Speedo still isnt working? The speedometers on the 92-96 camry's are controlled by a vehicle speed sensor. On the 92-93 models they have a different designed A140E That actually has two Speed Sensors. You probably disconnect one of those
Or if that's not the case, you may have shorted a fuse or something
