Many members here can easily handle those jobs. If you can do it yourself you can save some $$$. I'd use
NGK Iridium-IX spark plugs, it's an approved application for the 2000 5SFE (BKR6EIX-11). Check rockauto.com for price comparisons.
http://www.ngksparkplugs.com/
With every oil change you are supposed to get the
multipoint inspection. That includes visually checking things like leaks, CV boots for cracks, ball joint boots, brake pad thickness, top off all fluids, etc. What you can do is handle everything now, and then pay $35 for a dealer oil change 3000 miles later to get the same multipoint inspection if that makes you feel more comfortable. It's also a chance for the dealer to spot money-making opportunities without them giving you the excuse of $550 for doing really not that much more.
Battery service: clean the battery posts and clamps. Maybe they do a load test, but so does Autozone, for free.
Fuel injector cleaning: I don't think dealers hook up an external cleaner injector to the fuel rail any more. Most manufacturers no longer recommend the use of harsh cleaning chemicals unless there is injector related performance problem. It's now just a bottle of Techron in the fuel tank for you. Normally, just use Top Tier gas:
http://www.toptiergas.com/
You can google up some DIY maintenance articles. But you need to exercise caution with battery's acid, hot/moving engine parts, etc etc.
With 80deg temps now in Houston, you can use Motorcraft synthetic blend 10W-30 in the engine from Walmart. Great value. Use a larger filter for Toyota's 2.4L engine, or get a PureOne PL14477 from Pep Boys. Maybe your local Autozone has the 5qts Valvoline DuraBlend (synthetic blend) motor oil and a filter for $19.99. That's a great value too.
Originally Posted by tmpnsnty
I've got a 2000 camry LE, 4 cylinder. It's about time to get my 150K service done. But the dealership wants ~$550 for the following services (which the previous owner also did @120K):
-Fill Fluids to proper levels
-Engine Oil and filter change
-Replace Engine Air Filter
-Coolant Drain & Fill
-Replace Spark Plugs
-Transmission Fluid Exchange
-Tire rotation (just got new tires, even I don't need it they'll still bill me for it, because it's a package)
-Balance Tires (just got new tires)
-Comprehensive Multi-point inspection?
-Battery Service?
-Clean Electronic Fuel Injectors?
I want to do the 150k service myself to save some money. I've a pretty good idea how to do the first part of the list by myself from watching my friends/doing them myself. Though I have no idea what they meant by the last 3? The dealership employee explains them as checking "stuff" and cleaning your battery?! Not very helpful.
Also, are there any tips and advices? Anything else I should check at 150K? The previous owner changed the timing belt+brakes @90K, battery replaced @130K. Everything else is original. Thanks.
