How to change camber in front and rear gen 3 camry V6? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2010, 10:20 PM   #1 (permalink)
View kalentech's Photo Gallery
I want the camber to be like this the way they are in this angle but not as much as this gs300 maybe half of that.
Does anyone know how I can achieve this with my 92 SE V6 Camry?
kalentech is offline   Reply With Quote
Old 11-11-2010, 10:58 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
That's really negative cambers there! I wonder how long those tires are going to last.
This camber kit allows only +/- 1 deg adjustment:
http://www.rockauto.com/catalog/moreinfo.php?pk=926059
You can check with the dealer, maybe they have something that can give you up to 1.25 either way. On these cars I wouldn't want to go beyond -0.5 deg if even that.
Old 11-11-2010, 11:06 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
this picture is sick! it seems like car is using only the inner edge of tires, scary ...
Old 11-11-2010, 11:23 PM   #4 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
On the MR2, Toyota offers "crash bolts" to adjust the camber. They're basically strut->knuckle bolts with a smaller inner diameter to allow for more camber.
Standard diameter is 15mm, IIRC.
13.9mm, 13.3mm, and 12.4mm are available from here:
http://www.twosrus.com/catalog/produ...roducts_id=439
The Camry shares the same bolt/nut on the strut->knuckle housing at the rear, so it should be possible to use them. I'm not sure if the fronts are the same. Toyota offers different diameters for the fronts on the Camrys anyway.
Otherwise, you'll need an expensive camber kit with fancy camber plates.
BTW, that's too much negative camber for straight line stability. Just an FYI.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
