Ok. I have been laying in my cold, dark driveway for hours now. I think that it could be a wheel bearing issue. The left rear side seemed a little loose last time I rotated the tires. I didn't get around to changing the hub assy. I did on the right side when this symptom showed up. I jacked up the car again and spun the wheel. The bearing sounds suspect, it makes a very slight growling noise. I set the car down and rocked it from the left side putting pressure on the left rear rim. It definitely feels like a loose bearing. If I had a massive bearing failure, could this change the geometry of the rear wheel enough to make the strut rub? I could imagine that if the bearing failed badly enough, it could be cause the spindle to bend and change the angle of everything. Help guys...I really need it. Thanks
'94 Coupe with 220,xxx miles, rollin' strong....
