How To: Digital Clock Repair - 2000 LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2010, 07:56 PM   #1 (permalink)
View dsantoro's Photo Gallery
I had problems with my digital clock display working intermittently on my 2000 Camry LE. For a while I could tap it and it would work for a few minutes but it finally just gave out. After some testing I found that there some bad solder joints had developed that were easily fixed. My clock now works like new. If you have a soldering iron and are comfortable using it, this is an easy fix.
Here's what you need to do.
1) Remove the bezel surrounding the instrument cluster. To do this unscrew the two screws on the underside of the top of the bezel. Then gently pry the bezel off with a taped screwdriver. It is in there pretty tight, be forceful but careful. See Photo - there are tabs on the sides.
2) Unscrew the four screws holding the instrument cluster in and move it to the left side. No need to remove the wiring.
3) Remove the clock by pinching the side tabs ad pushing it back into the dash. I was able to carefully maneuver it out by passing it to the left through the instrument cluster opening. It seems like it won't fit, but if you keep trying different angles, it should eventually go.
4) Unplug the clock and bring it to your soldering station.
5) Remove the front tinted cover by gently prying the 4 tabs holding it in. I actually broke 2 of the 4 tabs but I was able to use electrical tape upon re-assembly and it worked fine.
6) Remove the 2 small screws holding the circuit board in
7) Gently pry the board out
8) On the underside of the board you will see a row of 4 surface mount resistors, see the circled area in the blurrycam pic.
9) Heat up the solder on each side of the 4 resistors to melt and re-flow it.
10) Re-assemble everything and reinstall the clock.
dsantoro is offline   Reply With Quote
The Following 5 Users Say Thank You to dsantoro For This Useful Post:
BamZipPow (04-05-2012), eluwak (05-12-2012), Gaoan (04-05-2012), OliverArk (02-01-2012), projektvertx (05-13-2012)
Old 11-15-2010, 09:56 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
nice write up
You should add this to Kens Sticky Update Thread
Old 02-12-2012, 03:38 PM   #3 (permalink)
View Gaoan's Photo Gallery
Clock now working!
Thanks for the post and especially the picture!
My 2000 Camry had the exact same issue. Today was the 2nd time I had pulled the clock trying to fix it. Sure enough, I checked the solder on each of the resistors and one of the resistors had pulled up just a little and the solder joint had a crack in it. I gently pushed it back down and reflowed the solder and yep, that did the trick. For the first time since I bought the car from a buddy 3 years ago I have a working clock and thermometer!!!
Yahoo!
Gaoan is offline   Reply With Quote
Old 02-12-2012, 05:08 PM   #4 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
speaking of which, is there anyway to add the temperature for the 97-99? ours extra button just resets the clock to 00 and idk about harness etc
adalex is offline   Reply With Quote
Old 04-05-2012, 11:23 AM   #5 (permalink)
Adalex, my Camry is a CE which is the base model. The only way I knew that my clock had a thermometer built into it before I did the simple fix was that I knew there was a temperature sensor under the hood already. Mine is located in front of the radiator towards the bottom. If you have the sensor then your clock should have a thermometer built into it.
Old 05-12-2012, 11:27 PM   #6 (permalink)
View eluwak's Photo Gallery
I just wanted to give a big thanks to the OP! My clock has been out since I bought my camry, I stumbled upon this post the other day and when I checked the clock sure enough I had 3-4 cracked joints. A few minutes later I had a working clock again
2000 Camry CE
eluwak is offline   Reply With Quote
