Could be axles starting to wear out, the differential could be getting tired having more gap than supposed to. Control arm bushings could be wore out causing the acceleration to push the control arms back (clunking), could be a bad transmission or motor mount putting too much twist on the motor allowing it to twist and axles are binding causing a clunk, could be loose lugnuts or wore out rim causing your hub assembly to spin in one direction hitting the inside of the rim causing a clunk
Inspect the front end ;;;; transmission, motor mounts, control arms, axles, ball joints, hubs, etc..
If something is wore out, you'll see it with the visual / wiggle test
