DIY : Piezo Buzzer Removal (ANNOYING) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2010, 10:57 AM   #1 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
3rd Generation DIY : Piezo Buzzer Removal (ANNOYING)
Who here hates when you have the key in the ignition and your car keeps beeping and beeping and beeping. Then you turn the ignition to ON and it KEEPS BEEPING
Obviously I do. LOL
Lets take that dang thing out of our camry then! Problem solved
First a list of tools you will need to remove this:
1. Phillips head screw driver
2. Flat head screw driver
3. 10mm Socket and Ratchet (Small extension helps)
4. Soldering Iron
Step 1:
Remove Negative Battery Cable from Battery
Step 2:
Remove the two bottom 10mm head bolts from the knee bolster:
Step 3:
Pry out the clips hiding the top two 10mm head bolts and remove the bolts
Step 4:
Remove the coin tray and remove the two phillips head screws from the coin tray holder. There is one more phillips head screw at the top left corner behind this plastic that needs to be removed as well.
Step 5:
Remove Knee Bolster
Step 6:
Pry out the Relay integration box with a flat head screw driver and remove the top plug
Step 7:
Carefully remove the cover of the relay (No pictures shown)
-- Here is where the piezo buzzer is located
Step 8:
Using a flat head screw driver, carefully pry around the outside of the board, pushing it past the plastic locks that hold the board in place
Step 9:
Flip the board over and heat up your soldering iron
After the iron is hot, heat the solder where the piezo is located and the buzzer will drop out once the solder turns into liquid form.
Step 10:
Re-install the board and do steps in reverse order
YAY!!! NO MORE BEEPING BEEP!
Old 11-16-2010, 11:07 AM   #2 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
No more beeping beep for you now. Cool DIY. Did you disconnected your negative battery terminal before the work?
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline   Reply With Quote
Old 11-16-2010, 11:08 AM   #3 (permalink)
Originally Posted by ty**20 View Post
No more beeping beep for you now. Cool DIY. How did you ever know where the piezo buzzer is at?
Wiring Schematics, and if you put your hand overtop of the integration box you can hear the sound get muffled
Old 11-16-2010, 11:14 AM   #4 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Ohhh this piezo! You should also do a DIY on changing the piezo in the engine bay that beeps when you lock and unlock your car. Great DIY but I want more from you !! Now you can listen to music with the door open and the key in the ignition
iovaykind is offline   Reply With Quote
Old 11-16-2010, 11:18 AM   #5 (permalink)
I will be doing a Temperature Warning Light circuit DIY soon
When your car gets to the point of overheating, a LED turns on to indicate its overheating
My 95 has keyless entry, but it doesnt beep when i lock or unlock the door
Old 11-16-2010, 11:26 AM   #6 (permalink)
iovaykind's Avatar
It should. I didn't know till it decided to work one summer for me lolll but now it doesn't work again so I want toxhange it out.
Old 11-16-2010, 11:29 AM   #7 (permalink)
I'll check my schematics out and see if I can figure out how the keyless circuit is setup in the camry's . I'll PM you if I find it
Old 11-16-2010, 11:31 AM   #8 (permalink)
Looking forward to see this.
Old 11-16-2010, 12:04 PM   #9 (permalink)
iovaykind's Avatar
The piezo buzzer is in the engine bay by the driver side corner.. hopefully you can find a way to replace it cause I can't
Old 11-16-2010, 12:06 PM   #10 (permalink)
I can't find any wiring schematics for the alarm system
could u take a picture for me of the location?? lol i feel like an idiot
Its a lot of work actually, variable resistors, Temperature sensors, Capacitors, LEDS, Circuit boards. Its a fun little project though. All together it costs about $50.00 to make it
Old 11-16-2010, 12:14 PM   #11 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
this is from the piezo chirper that is under the hood that is bad. its the small plastic thing typically tied to your brake booster line on the master cylinder. i have a thread on this somewhere, but is basically a matter of ordering a new one for under $15, cut the old one out and splice in the new one. search "piezo chirper" and you should find it.
Old 11-16-2010, 12:45 PM   #12 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
^ I believe it is red as well...its circle and red iirc....just replace it w/ a bad ass piezo...and u shouldnt have a problem....
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 11-16-2010, 12:48 PM   #13 (permalink)
iovaykind's Avatar
Is there a special piezo buzzer that needs to be switched in or can it be any cheap buzzer?
Old 11-16-2010, 12:52 PM   #14 (permalink)
jtex2717's Avatar
im sure as long as its 12volt ready....any one of them should be fine......
IM BAAAAAACK!!!!!!!
Old 11-16-2010, 02:11 PM   #15 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
I did this to my Taurus, then my Stratus, then my Camry. Hey, the smallest dings or squeaks or rattles annoy me, so it was one of the first things I did to this car! I can't remember if it was this car or the Stratus but I couldn't open the door without listening that annoying beep! No more!
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Tags
buzzer, chime, chime removal, piezo, piezo removal
