Maybe all you need are new struts (not even going into the sports setup like Tokicos, Eibach, H&R etc)?
A new assembly like the QuickStrut is only $131.79 front and $127.89 rear plus shipping. A new assembly may be the cheaper way because mounts should be replaced each time too. Monroes come with lifetime warranty.
I was just giving him a suggestion of sport struts because the stock camry struts are really kind of smushy to begin with. Actually the entire steering system of the camry sucks stock. lol
Yes I know what you mean. Toyota's suspension systems don't win awards.
I actually was thinking of Tokico Blue but figured maybe he's got old beat up struts is all. It's cheaper with regular stuff.
Tokico struts + H&R or Eibach springs. Done. Well, other than a new rear sway bar and upgraded end links.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Dude....go to autozone or advamced auto parts...get 4 Monroe quick strut assemblies and call it a day....it will be a bit pricey but you will be able to unbolt one and bolt up the other and you will have a stock quality ride...call it done...if you want to go on the cheaper side...get 4 Gabriel or Monroe struts and put your same springs on them...and call it done...u will have a stock quality ride...
__________________ Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
If OP doesn't need to replace anything else (rubber bellows, spring seat, etc), then only buying struts should save some money (especially with the frequent buy-3-get-1-free type of deals).
Otherwise just get QuickStruts and that's the easiest. Do check alignment afterward.
I personally prefer the Gabriel. But their later valving seems to be softer than before at lower rod velocities.
Well I thought I was going to replace the struts on my car as the car seemed to float & bounce too much over bumps. I was also hearing a clunk sound in the rear. While looking underneath I noticed that the rear sway bar bushings were worn as I could get the sway bar to move up and down inside the bushing. So, I spent $13 at Autozone and then I replaced 'em and not only did the clunking go away, but the car's ride firmed up enough that I'm happy w/ it now....
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes .
Gen 4 have defective front mounts that may give you the clunks. In any case it's best to replace at least the front mounts with struts on any car (the rears on these are usually in good shape for reuse).
Originally Posted by Pvt-Public
I just got 4 Monroe Quick Struts for my '99, may have them installed by tomorrow evening I'll let you know how it goes.
